Mowing Mower deck noise..........
/ Mower deck noise.......... #1
MuncyBob
Platinum Member
N Central PA
PT 422
Was cutting the grass yesterday and noticed an intermittent noise from the mower deck...was hard to clearly hear it at first with the noise from the PT and deck running along with the headset I always wear when mowing...thought maybe I hit something and perhaps bent a blade. Back to the garage...raised the deck..everything appeared normal...blades were ok and had clearance...cleaned the underside of the deack anyways while I had it raised. With the deck on the ground and PT running at 1/4 throttle, hit the PTO and after a few seconds I hear it again. HMMM, decided to remove the deck covers...GLAD I DID! It seems that the bolt holding down the right pulley had come out! It was actually resting in one of the "spokes" of the pulley! Now I know it didn't come from PT that way because I remove the covers once in awhile just to clear out the accumulated grass in there. Replaced the bolt and tighten it down and no noise. Was wondering if anybody else has had this happen...and any suggestions on best way to prevent this from happening again(use a lock washer, lock-tite, etc?)...if that bolt had been loose under there and boucing around I'm guessing I could have had a lot of damage.
/ Mower deck noise.......... #2
I am a long time believer of Red LockTite and Nylon Locking nuts where ever possible. Also use minimum Grade 5 nuts and bolts for most anything beyond lawn furnature.
Still check things regularly as well. Glad no apparent damage this time.
Rip
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
17601CFL (A61572)
17601CFL (A61572)
2021 Scag Turf Tiger II 52in Zero Turn Commercial Mower (A64194)
2021 Scag Turf...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2007 Mercedes-Benz C230 Sedan (A64557)
2007 Mercedes-Benz...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A67148)
2016 FORD TRANSIT...
