Mowing mower cut quality
/ mower cut quality #1
Zeke
new york
I am considering purchasing a 422 with 60" mower deck. My question is how good a cut can I expect? The lawn is flat with no weeds and a very fine grade of grass similiar to a golf course. It is currently being professionally cut by a top of the line exmark mulching mower. Will I see a difference? What about the quality of the blades, their speed etc...? Thanks.
/ mower cut quality #2
Zeke - I have the 425 with the 60 inch deck - I also have a
high quality turf grass lawn - no weeds and very dense.
Before I purchased the 425 i used to cut it with a commercial Buton mower - before that i used a Locke reel mower
I have to say that I am happy with the cut - (the 48 inch will give you a little nicer cut (I had that deck from them as well but decided it was not big enough) - but overall the quality is good. They use a thin blade design which I happen to like - you can get them really sharp and they produce a clean cut -
I have not tried a mulch type blade yet - but I suspect you would need to put a baffle in the rear to keep some clippings within the deck (they use a rear discharge) - I also think that the rear discharge disperses the clippings better - I cut my lawn once and then after the clippings sit for a little while and dry up in the sun - I cut it again ay a 90 degree angle - this leaves very little clippings left - I also modified my deck - to produce a stripe pattern - (See my earlier postings with pictures) - The one thing I will say to you is that I would reconsider the 422 in favor of a 425 - the engine really does have quite a bit more power - far more than the peak hp difference - I think it has almost 20 percent more torque - that really makes a difference when mowing -
mowing, especially with a 60 inch deck is the most demanding job you will put the machine through - if you like the 422 maybe consider a 48 inch deck - just an opinion
/ mower cut quality #3
AMEN especially the suggestion of the 48 inch deck.
ZEKE: if you do a search on decks, mowing under power trac you will be able to write a book once you have digested all that info ... and you lawn will look nicer than before /forums/images/graemlins/cool.gif
/ mower cut quality #4
I don't recall seeing that one about the stripping. I did the search but Deadstick's thread was the only one that came up. Could you post the link
Thanks
Tim
/ mower cut quality #5
here are just a few:
Re: New Blades and Striping Kit Power Trac bubenberg 06/28/02 06:34 PM
Re: New Blades and Striping Kit Power Trac bubenberg 06/25/02 08:53 PM
Re: PT 4xx Finish Mower Cut Quality Power Trac PTRich 05/20/02 05:53 PM
if you like to go to the stripping U see lawnsite.com, they talk about this year round.
/ mower cut quality #6
If you look at my threads - it is "Eds pictures of 425 and attachments" - there is a picture of the mower with the full width rear roller that provides the stripe
/ mower cut quality
Thanks for the advice. Paying 30% more for 20% more torque is a tough one but maybe it's necessary.
/ mower cut quality #8
You might want out check out the 48" mower instead of the 60" mower for the 422. See what the factory has to say.
2013 Chevrolet Tahoe SUV (A64557)
2013 Chevrolet...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2006 Chevrolet Express 2500 Cargo Van (A64556)
2006 Chevrolet...
JOHN DEERE QUICK ATTACH PALLET FORKS (A64278)
JOHN DEERE QUICK...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
