Mower blade orientation make a difference?
/ Mower blade orientation make a difference? #11
As I understand it, brush hogs tend to not have sharpened blades, for two reasons. One is that good luck keeping that edge if you are using it for its design, the second is that by breaking, instead of cutting, you increase the chance of killing the plant, which tends to be the more desireable result when brush hogging.
Another is that a sharp blade will slice saplings off vs shattering them like a blunt edged blade will. A sliced sapling could go through a tire unlike a shattered one.
Aaron Z
/ Mower blade orientation make a difference? #12
I would think a new blade is a sharp blade.
However razor sharp is not desired, nor is a dull flat sided blade, or the tips worn down..
/ Mower blade orientation make a difference? #13
The new PT brush hog blades are not sharp; they have about a 1/16-1/8" radius at the front of the bevel. That is to say the blade is ~3/8" thick, with a leading edge bevel down to 1/16-1/8", where it is unsharpened and radiused.
From personal experience, I think that having a sharp blade if you are cutting brush is risky, because sooner or later, you will hit a sapling just right and it will end up with a knife edge on it that will slice your tire. That said, you don't want a totally round edge for HP and efficiency reasons.
All the best,
Peter
/ Mower blade orientation make a difference? #14
I do believe some of you are mixing up brush blades and finish blades.
I cut lawns for about 20 years, and sharp blades are necessary, or your customers will notice the shredded look and can your but. You want the blades sharp enough to make the cut grass to almost disappear.
I also have a bush hog and would not give it a sharp edge as it will dull rather quickly.
I have installed many bush hog blades and they are somewhat sharp, at least the ones I buy are.
If you want to shred, do so, and if you want to cut, then you know what to do.
/ Mower blade orientation make a difference? #15
I think I'll go sharpen the strings on my trimmer. It should cut lots better.
:D
Bruce
/ Mower blade orientation make a difference? #17
Trimmer RPM's are over twice as fast as mower blades. Faster the RPM the duller the surface can be and cut vs. shred.
MoKelly
I've notice some string isn't round and has "sharp" edges. Maybe Bruce could use that instead of sharping the strings on his trimmer. :laughing:
(INOP) 2000 FORD E-350 XLT SD 11 PASSENGER VAN (A59823)
(INOP) 2000 FORD...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
Great Dane Van Trailer (A61307)
Great Dane Van...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
