Moving Round Bales
/ Moving Round Bales #11
TS,
I have a 3110d with a Koker 160 loader and ROPS. I move round bales with the 3PH that weigh approx 1000+ Pds without difficulty. I have the rear wheels extended to maximum width and the rear tires are loaded with windshield washer fluid. I also loaded the front tires and believe this added approx 50-60 Pounds to each tire. Some folks do not recommend loading the fronts but I have not experienced any problem. I would think that the total weight of the tractor with all of the above is approximately 4200 pounds. The tractor has more that adequate power and stability to lift and carry the hay without concern. I can transport the hay up or down an incline that is in excess of 30 degrees. However, I always scoop a load of soil into the loader bucket before hand. I experimented with an empty bucket on the inclines and determined that I could allow the tractor to roll backwards down the incline very slowly with a round bale and hit the brakes which made the front almost get airborne. I did not get any feel of instability performing the same experiment with the bucket loaded. I performed these experiments very slowly with the hay very low to the ground and my hand on the 3PH lever in order that I could drop the hay immediately if need be. Use extreme caution if you attempt to move round bales on any terrain other than level with tractors of this size. My 3110d will negotiate more extreme inclines with round bales than my International 444 but the International does not have a loader to act as a counter weight.
I would have serious reservations concerning handling round bales with a loader on the 3110d or smaller. I use a Belarus 570 that weighs in excess of 10000 pounds to move hay with a loader spear. Whatever you do, make sure you experiment and use extreme caution to determine the stability of the machine to handle the heavy loads. Good luck.
/ Moving Round Bales #12
My rear tires are full. I have my bales delivered to me and I then stack them in the barn. I don't move them very far and I take my time. No bouncing. Using the forks in is not likely that I will tip over because the bale will fall of first.
/ Moving Round Bales #14
I have a 1700, I can stab the bale and start to lift and the front end just comes off the ground. I have no weights on front and I dont know how much weight it would take to balance the tractor. but even with weights I dont know if it would be good on the tractor to lift it, those bales Im working with are about 1200 lbs. I think Ive seen on this form that the lifting capabilities on a 1700 are 750 or 800 pounds.
What spear did you use (TSC?) or did you build a custom one?
/ Moving Round Bales #15
WOW zombie post!!!:laughing::eek::confused3:
If those random people are still around hopefully they will answer you 12 years later??!!
/ Moving Round Bales #16
Hear I was reading through this and realized the date, he definitely pulled this one from the vault. I can not believe I joined almost 10 years ago now!
/ Moving Round Bales #17
good to see you again. I will be in your neck of the woods this weekend.
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2011 Volvo S80 Sedan (A59231)
2011 Volvo S80...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
