moving rear lights to inside ROPs
   / moving rear lights to inside ROPs #21
I just got two 1-1/8 inch cap plugs at hardware store for a whole 56¢ each... Fit fine....
Dale
   / moving rear lights to inside ROPs #22
I just got two 1-1/8 inch cap plugs at hardware store for a whole 56「 each... Fit fine....
Dale
Thanks, I知 going to the hardware store tomorrow and I値l see what they have, I値l probably put some silicone sealer around the area that the frame sits in just to keep any water out, I知 sure it would be fine without it but might as well use it since I have it.
Jim.
   / moving rear lights to inside ROPs #24
Dale
Which hardware store? Local one or a chain?
   / moving rear lights to inside ROPs #25
   / moving rear lights to inside ROPs #27
Can I ask why do you guys even keep these lights mounted? Just curious, because I'm thinking to just remove them altogether, unless there's a reason I shouldn't.
   / moving rear lights to inside ROPs #28
You should keep proper lights mounted for hazards, direction and general lighting in the instance your mowing or traveling on road sides or down roads to mark your vehicle (along with the SMV triangle). Beyond that, you could remove them but be careful of leaving electrical plugs open to the environment as corrosion on the plug could become an issue
What He said ^^^^^^^^^
   / moving rear lights to inside ROPs #30
I do have to get out on public road because I have no way to cross a creek to get to back side of my property... Love the emergency flasher for road use other wise I would get run over at 14MPH...
Dale
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
UNUSED 72" HYD ROCK GRAPPLE (A54757)
UNUSED 72" HYD...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
Electric Mobility Scooter (A55853)
Electric Mobility...
2007 Volvo VNL Truck Tractor (A55218)
2007 Volvo VNL...
