moving rear lights to inside ROPs
/ moving rear lights to inside ROPs #21
I just got two 1-1/8 inch cap plugs at hardware store for a whole 56¢ each... Fit fine....
Dale
/ moving rear lights to inside ROPs #22
I just got two 1-1/8 inch cap plugs at hardware store for a whole 56「 each... Fit fine....
Dale
Thanks, I知 going to the hardware store tomorrow and I値l see what they have, I値l probably put some silicone sealer around the area that the frame sits in just to keep any water out, I知 sure it would be fine without it but might as well use it since I have it.
Jim.
/ moving rear lights to inside ROPs #25
/ moving rear lights to inside ROPs #27
Can I ask why do you guys even keep these lights mounted? Just curious, because I'm thinking to just remove them altogether, unless there's a reason I shouldn't.
/ moving rear lights to inside ROPs #28
You should keep proper lights mounted for hazards, direction and general lighting in the instance your mowing or traveling on road sides or down roads to mark your vehicle (along with the SMV triangle). Beyond that, you could remove them but be careful of leaving electrical plugs open to the environment as corrosion on the plug could become an issue
What He said ^^^^^^^^^
/ moving rear lights to inside ROPs #30
I do have to get out on public road because I have no way to cross a creek to get to back side of my property... Love the emergency flasher for road use other wise I would get run over at 14MPH...
Dale
/ moving rear lights to inside ROPs #31
Yeh, mine's ain't going anywhere other than down our private road to a neighbor's maybe, so off with the lights.
I don't mean to hijack this thread, but can anyone give me a heads up how to disconnect them? I know where the plug is, but not for sure if you just pull that connector apart, twist it, or what? I tried pulling them apart a little but no give, so didn't want to wreck the connector doing it the wrong way with too much force.
/ moving rear lights to inside ROPs #32
They are just push in, pull out ...
Dale
/ moving rear lights to inside ROPs #33
What DL said, too!
/ moving rear lights to inside ROPs #34
Thanks fellas, my rops are now officially rocking the clean shaven look.
/ moving rear lights to inside ROPs #35
I wanted to keep the lights on the outside (more room when using backhoe), so I installed springs to let the lights flex if I get to close to a tree etc.
/ moving rear lights to inside ROPs #36
I am a little surprised that folding or flexible lights are not an option (standard for some). They are so common for wing mirrors on cars. The road we are on is short and seldom used. I may go clean shaven, too.
/ moving rear lights to inside ROPs #37
Where'd you get the springs?
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2019 Chevrolet Express Box Van, VIN # 1GB0GRFP7K1370206 (A65563)
2019 Chevrolet...
8 Nissan Wheels & Tires (A65579)
8 Nissan Wheels &...
3142 (A63117)
3142 (A63117)
New Metal Fusion Mig 160 Welder (A65579)
New Metal Fusion...
