Moving Field Stones
/ Moving Field Stones #1
boblegg
Derry, NH
1999 B2710
I am new member and looking for tips on moving field stones with my FEL in 2710 in frozen and muddy uphill conditions of NH. Tried backing (front wheels sunk and dug in) and tried again going forward to get through a very soft spot with a load of field stones in FEL. (No luck) Finally dumped the stones and backed right thru the mud to the frozen area. Best to go forward or backwards uphill? I do have a RB72 for counter weight on the back.ThanksBobNH
/ Moving Field Stones #2
Using a stone bolt and pulling the stones out of the field, keeping the weight off the tractor, or not as full a bucket and more trips, would be my suggestions to start.
Backing or driving up hills, I would say how steep are they?, keep the bucket as low as posssible and drive the way you are most comfortable with again keep the bucket low. Tim
/ Moving Field Stones #3
The way your r-4's are mounted on your tractor, they will give you the best traction going forward, in 2wd or 4wd. If you want more traction while backing, turn the front wheels around so the bars are pointing the other direction (forward if looking on top of the tire).
Sounds like either some additional weight in your ballast box, and/or fewer field stones will help you get the job started. Also, doing the job when the ground is drier will help as it sounds like you are having the most problem in wet, soft spots. You will gain some experience as you go along, and will find out what works and what doesn't. The outfit you have should work well for moving a lot of field stone. If you have a long way to travel, then a carrying platform on the 3ph that you could load field stone onto would give you rear weight as well as increase your efficiency per trip.
I sometimes work flat stone around (with the FEL) so I can prop it up in the air enough to back under it with a 3ph platform, saving on the bullwork as much as possible. Otherwise I roll the stones onto the platform. If the ground is dry, I will use the stone boat. But that doesn't give me any weight on the tractor wheels for traction.
/ Moving Field Stones #4
Not so long ago " Bird" posted a picture of a hicth that attaches to the three point.
Make one of these and you can pull larger stones by putting down pressure on the rear wheels. At the same time keep the bucket full of stones. Only pull straight downhill or straight uphill and always keep one hand on the bucket controls and be ready to stop the tractor quickly. If going downhill with a very large round rock it may have a tendancy to roll to one side and pull the tractor that way. This may not be a pleasant experience and should best be avoided.
Egon
/ Moving Field Stones #5
Bob,
Looks like mud season has arrive for you,so in a month I'll be up to my axles.
The best way I found out to remove stones..going down a hill I back down w/the fel about 4" off the ground also I go up a hill the same way.
When traveling thru rough or muddy surface I rather back thru it..I do use tire chains and thats a good help.
You could always do it the old way like on the farm..get to the area your working couple hours early before the warm temps and sun thaws the ground..man do I remember those morning this time of year. /w3tcompact/icons/eyes.gif
/ Moving Field Stones #6
Are your rear tires filled? That will add a bunch of weight. A blade isn't that heavy. Any form of rear weight will help traction.
You might also consider tire chains.
As a last resort, load fewer stones, or roll them down hill then bring them back up by an easier route if that's possible.
Good luck.
Thanks for imput everyone. Was on site at 8AM today and low temp had frozen all up solid, but yesterday before leaving the 12" plus ruts of mud, we filled them with brush and waste chunks of cedar logs from our new home. Ground remains frozen in woods except for this 20' section of mud. I made 4 trips this AM before ground started getting soft. Backing up seemed to work best. My R4's are calcium filled and they do have chains. It was the fronts that got bogged down in the mud yesterday. I need the field stones from my rear stonewall to build field stone chimney and retaining walls. Just know that March and April won't be more favorable in regards to MUD. More pics on http://homepage.mac.com/boblegg/LeggLogHome/PhotoAlbum15.html
/ Moving Field Stones #9
Great photos..Looks like a great day for outside work.
Maybe a little ditching on the wood road might help to keep the dirt dryer.
/ Moving Field Stones #10
Bob
Great Pictures. I sure like view and Log house. /w3tcompact/icons/smile.gif Is the house being built for you?
My Katahdin Log dealer is doing the construction. I'm coming up with these odd jobs to justify my Kubota. Actually the stone mason gave me a deal for using my own stones. He'll also get his tracked loader in their sometime before end of April. Thomas, side ditches are a good idea, I'll try to add them. Do have to remove more stumps along the way before that. I did the chainsaw bit in the summer and fall before I bought the Bota.
/ Moving Field Stones #12
I like to back down hills or slopes when transporting any heavy weight in the FEL. I learned quickly one day that when you go down hill frontwards with weight in the FEL there is a lot less weight on the back wheels which are the only wheels with brakes.
In 4WD the front wheels help in braking the tractor, but backing down gives me better control of the decent. If the hill side is muddy or slippery your brakes may not stop you. Lowering the FEL in reverse can slow you down safer than if you are traveling foward. However,I would rather drive up hill than to back up.
I like using a small trailer for moving stones I can load by hand and then throw a couple of larger one's in the FEL. I used and old car hood for transporting stone for a number of years, the wide surface smoothed the road real well, and the low profile made it easy to roll stones on wilt the FEL or by hand.
Randy
/ Moving Field Stones #13
Boblegg, I have heard that wood chips will firm up a muddy spot. I have no experience with them though.
Billfires
Well I sort of used wood chips. How about waste ends of my 5x5 cedar logs. It didn't work, the mud swallowed them. Thought that morning after 10 degree night would of firmed up. Unless winter returns with a hard freeze, I'll be out of luck until drier weather. No snow to plow and driving in deep mud has been unproductive work. Bob
Steel Blasting Shed (A62679)
Steel Blasting...
SKID STEER PLATE GRABBER (A62613)
SKID STEER PLATE...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2014 Chevrolet Camaro (A62613)
2014 Chevrolet...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
