Moving a windmill
   / Moving a windmill #11
Like mentioned above, id probably rent a all terrain forklift . They have a pretty long reach and are quite nimble in those sorts of places (all wheel steer). Id likely rig up some sort of a cage for the forks to work out of and remove it piece by piece (pr section by section if not too heavy)from the top down., I imagine the rental on one wouldnt be outrageous for the weekend.
A genieboom would also work, but wouldnt have the capacity of the forklift.
Looks like its going to be an interesting project. Keep us posted.
   / Moving a windmill #12
When I was growing up, we tilted them over to move them. We did some relatively big ones that way. Take the top head off and, observing safety precautions, tilt it. It is hard to tell from your picture if you have a clear path.
It is likely that dempster has a weight for them, but I don't think it is that much.
Chris
   / Moving a windmill #13
Hope you are not afraid of heights. The secret is to never look UP. Look down all you want. I took down a 32' tower with a good fan and motor a few years ago and set it back up at my ranch. Here's a few tips:
A gin pole is a 4x4 lashed to one of the legs of the tower at the very top. You want to have an eyebolt at the top which extends well above the top of the gearbox. Use this to remove the fan as necessary, tail and gearbox. They are loose at the top so you want them off before the tower comes down. You really need 2 people to get this done. One to attach the hooks and line and the other to run the tackle. A smart move is to use a truck on the ground in case the person below is a lightweight. You may need more rope for that method, though in case you are using more than 1 to 1 on the pulleys. The center of gravity of your empty tower is about 2/3 of the way up the tower. So, if you use a rope to pull the tower from the top, and another rope on your truck to hold the tower back, you can drop the tower in one piece using a slow pull on the tower rope and someone who knows how to drive on the holdback end. If you have some doubts about your abilities in using this method, instead of cutting (better to unbolt) all the legs, just unbolt 1/2 of them and use the remaining ones for hinges. Since its angle iron at the bottom, you will need to saw thru one side of the angle iron to allow it to bend in the ground plane. If it gets away from you, it probably will bend the tower so take it slow. Erecting it all back up is the reverse. A front end loader sure helps a lot to get the lift started. You need to stake the ground legs to prevent them from slipping when you pull. You also need the restraint rope because the tower may carry thru if you pull too fast and it could come down on the pulling side/person/vehicle.
Its really simple but attention to details and doing prep work pays off in the end. Assembling the tower in sections is a slow, painfull and possibly dangerous process. There's just no good place to stand. If you are really good, have the cemented in ground anchors already in place when you put the tower back up. If its for water pumping, you need to get the well dug FIRST so you know it was worth your time. That's my 2 cents. I did it all by myself by controlling the pull and holdback ropes together. I used a ground pulley to run a return line back to me.
The only real trouble I had was the outside temperature. It was -20 below windchill when I climbed the tower to put the fan on the gearbox. I used my beard to hold the fan bolts while I fumbled at getting them in the driveshaft hub 1 at a time.
She's still standing !!!
   / Moving a windmill
Thanks for the input Jason & Chris . I do have a 8000 lb capacity forklift But I,m not sure of the reach , I,ve had it about 20 foot . But its Pretty soft ground back there so I doubt it would be much use other then a dead weight Or using it for the tipping puller because of the mast & Cage Protection in case something went wrong .
Also thankyou zzvyb6 for the detailed explanation . There is no Blades or tailpiece on it As they were pretty much ripped off during a windstorm a few years back , Allthough They were pretty well tore up I,m now wishing I would have saved the pieces .
That being said I,m Wondering if its necesary to even remove the gear box before attempting to lay it down . Its Surounded by big trees on all sides Except for one little clearing that You can see in pick 1 & 5 that it could be pushed that direction after some tree branch removal .
If & when I can get it down , Would it be posablle to Remove the lower tower section to Shorten it some as I would not want it quite as tall as it is now as it will be out in the open .
I,m even figuring worse case scenerio that its not rebuidable without a lot of Expense . Still Putting a well down Putting the WM over it & Using the base for a pump house & it would just be for looks if that makes any sense . If any one has pics of theres I sure would like to see them if posable. Thanks again for the great input. Bob
PS . I see Your in Manhattan Chris , The damage that Happened to this WM is from the same storms that did the damage up Your way a few years back.
   / Moving a windmill #15
These pix are from a windmill museum in Indiana.
   / Moving a windmill
Great pics, Thanks again zzvyb6 . I never Realized there were so many different types . Very interesting . I,ll let Ya,ll know how it goes . Bob
   / Moving a windmill #17
As long as there isn't any thing to disturb the air flow I dont think it would be a problem.
Use the top 12" of lower section for the new base to bolt the uppers to.
I'd leave the top 12" bolted on the next section use the rest of the leg steel tack them in position so when you pour the base with the angles in it will lign up correctly
tom
   / Moving a windmill #18
If it was hit by those storms, it must be some sort of stout!
Good luck.
Chris
   / Moving a windmill
Thanks Tom that makes sense . It will be more out in the open so I beleve going 8 foot or so shorter shouldn,t cause any problems .
Thanks Chris , The Only damage was the Blades & tail section because the broken tree linbs blew into it . If it wasn,t surounded by the trees I Beleive it would allready be down. :D . Bob
   / Moving a windmill #20
Hey zz, where is this windmill museum? Might be worth a road trip! Thanks for the pics.
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2006 Ford F450 XL Bucket Truck (A47384)
2006 Ford F450 XL...
2020 Nissan Altima Sedan (A50324)
2020 Nissan Altima...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
