Move hose with quick disconnect between loader and 3ph top link
   / Move hose with quick disconnect between loader and 3ph top link #1
hz293
Kalama,WA
Kubota B7510HSD
I have not seen this addressed when I searched the posts.
I have a need for the 3ph top link to be hydraulicly activated but will have no need for the bucket while I'm using the 3ph. Instead of using a remote or a diverter is it possible to quick disconnect one of the hoses to the loader and quick connect it to the 3ph top link cylinder? If so, can it be either the up and down OR the curl?
Harris
   / Move hose with quick disconnect between loader and 3ph top link #2
Sure it is possible. Most people use the bucket curl function when using a diverter so I would use it for what you want to do also. You would need to put QD's on both the work port hoses for the curl spool.
Thanks Mad, I already have a QD on my loader hoses. I'll also put one on for the Top link. If my idea works ( or not ) I'll post some pictures. Right now I'm not going to say what it is but when you see it (if it works), you'll dig it.
The problem I've run into with my Kubota B7510HST 21hp CUT is that they make regular attachments for CUT's but there alot of attachments that are made for larger tractors and skidders that I could use, especially with a real bad back, but they're not made for CUT's and SCUT's. We'll just see about that. (I Hope)
Harris
   / Move hose with quick disconnect between loader and 3ph top link #4
Yes, you can do it, but it becomes a real PITA. I did this on my old Ford 1700, to run a PHD assist, and grapple. Even a manual diverter valve is better than swapping hoses around, if you dont want the $$$$ of an electronic setup (Fasse or WR Long). I went with the Fasse on my JD, and very glad I did.
   / Move hose with quick disconnect between loader and 3ph top link #5
Well hurry up so we can see what you got going...
I was going to say that Mad has a good point about using the curl if you can. Otherwise, if your loader arms leak down for whatever reason, you're kinda screwed and have to switch them back again.
   / Move hose with quick disconnect between loader and 3ph top link #6
JerryG, that looks exactly like what I was looking for. Thanks
Harris
2012 John Deere 6170R (A57148)
2012 John Deere...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
Towable Diesel Generator (A59228)
Towable Diesel...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
