Mounting bracket help!
/ Mounting bracket help! #1
WayneB
Elite Member
New Hampshire
Kubota B-7500
I have a Char-Lynn motor # 129 0003 002 I believe it is a J series motor and I can't figure out what mounting bracket to buy? Mounting is defined as 5 Bolts on 1.775" dia. B.C., 1.241" dia. pilot.
By now you can figure out that I know little to nothing about hydraulic motors so please take it easy on me!
Thanks in advance for any assistance and direction you can provide me with.
Wayne
/ Mounting bracket help! #3
Wayne
Wayne,
these motors are not made to any SAE standard so a mount may be hard to find. I also don't remember if they where ISO or DIN mount either.
I guess one question that comes to mind is what are you trying to mount it to or drive with it? A company called BSF Incorporated (BSF Inc. | Pump Mount Technology, Pump Motor Adaptors, Shaft, Couplings, Bellhousings, Sound Reduction - Home) specializes in custom mounts for pumps and motors.
Trying to adapt any of the SAE "standard mounts will be very difficult since the smallest pilot diameter if the 4F which has a 1.781 diameter.
Not sure if Parker, or Ross, or White make a mounting bracket for motors this size either.
Roy
Thanks for the input Roy and JJ. I have looked at the surplus site and the northern tool. Both might have something that can be modified to work. Plan on using it to rotate the chute on my front mount Kubota snow blower.
Wayne
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
NEW HOLLAND T4.75 POWERSTAR TRACTOR (A62130)
NEW HOLLAND T4.75...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
7x14 Utility Trailer (A61165)
7x14 Utility...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61567)
2025 GIYI GY-PG72C...
