Mounting bracket help!
/ Mounting bracket help! #1
WayneB
Elite Member
New Hampshire
Kubota B-7500
I have a Char-Lynn motor # 129 0003 002 I believe it is a J series motor and I can't figure out what mounting bracket to buy? Mounting is defined as 5 Bolts on 1.775" dia. B.C., 1.241" dia. pilot.
By now you can figure out that I know little to nothing about hydraulic motors so please take it easy on me!
Thanks in advance for any assistance and direction you can provide me with.
Wayne
/ Mounting bracket help! #3
Wayne
Wayne,
these motors are not made to any SAE standard so a mount may be hard to find. I also don't remember if they where ISO or DIN mount either.
I guess one question that comes to mind is what are you trying to mount it to or drive with it? A company called BSF Incorporated (BSF Inc. | Pump Mount Technology, Pump Motor Adaptors, Shaft, Couplings, Bellhousings, Sound Reduction - Home) specializes in custom mounts for pumps and motors.
Trying to adapt any of the SAE "standard mounts will be very difficult since the smallest pilot diameter if the 4F which has a 1.781 diameter.
Not sure if Parker, or Ross, or White make a mounting bracket for motors this size either.
Roy
Thanks for the input Roy and JJ. I have looked at the surplus site and the northern tool. Both might have something that can be modified to work. Plan on using it to rotate the chute on my front mount Kubota snow blower.
Wayne
SAMSUNG ESPOKE REFRIGERATOR/FREEZER (A62131)
SAMSUNG ESPOKE...
CAT D3G Crawler Dozer (A61166)
CAT D3G Crawler...
2023 RIPPA R360 EXCAVATOR (A62129)
2023 RIPPA R360...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
2015 FREIGHTLINER  2500 4X2 SPRINTER VAN (A59909)
2015 FREIGHTLINER...
HD 24ft Free Standing Corral Panel with Feed Bunk (A61166)
HD 24ft Free...
