Mounting Auxiliary Lights
/ Mounting Auxiliary Lights #1
lzicc
Platinum Member
Pittsburgh, Pa
Kubota B2650
I want to mount extra lights on my B2650 for nighttime use when plowing snow. Since my garage door is only 7' tall, my ROPS is always folded. Where would be a good place to install lights for the front and rear with the ROPS folded that would me useful?
/ Mounting Auxiliary Lights #2
For height I'd install them on the ROPS. It will take little slack to permit the ROPS to fold, all you need to do is put the ROPS back up when you go outside. The cable should go up the hinged side that stays together when folded.
I thought about that, but I know me and I'll forget to put it down when pulling in and smack the house.
/ Mounting Auxiliary Lights #4
On your loader arms will get you some height.
And with them ahead of you there is no glare when you turn to look back.
That's a good idea. I'll have to look at that.
/ Mounting Auxiliary Lights #7
This is what I used to mount my light bar to the ROPS;
Amazon
AKD Part Tube clamp, 2pcs Powerful Magnetic Base Mount Bracket Sucker Holder LED Light Bar Roof Magnet Bracket for LED Work Light Driving Lights Off Road Lighting IMG_0058.JPG
They make some really cool stuff anymore. Now I need to find the right light. They make so many, it's hard to pick one. I obviously want something bright. I am thinking about wiring it to my headlight switch so when I turn the headlights on, all the lights come on. It may be a cleaner way of doing it.
Amazon
AKD Part Tube clamp, 2pcs Powerful Magnetic Base Mount Bracket Sucker Holder LED Light Bar Roof Magnet Bracket for LED Work Light Driving Lights Off Road LightingView attachment 625514
/ Mounting Auxiliary Lights #9
Those are exactly what i bought to mount my lights. Just need to do it before the snow gets here.
I rarely lift my rops due to garage height, and with the magnets, i can turn them backwards when using my rear blade, which is what i use to clear my driveway.
Amazon
/ Mounting Auxiliary Lights #10
Any of you have some pics of your mounting using the magnetic base?
Cheers,
Mike
/ Mounting Auxiliary Lights #11
/ Mounting Auxiliary Lights #12
I had the same problelm on my B2650. Cant have my rops up and get in the garage. I fabbed up these mounts to keep them up high and just get in my door. Has worked out very well.20180326_094538.jpg20151215_101203 (450x800).jpg20151215_101616.jpg
/ Mounting Auxiliary Lights #13
Did you ever get your lights mounted?
My lights, magnets, and wiring harness are still in a box in the garage.
Good thing we've had a mild winter so far.
/ Mounting Auxiliary Lights #14
the problem with mounting lights near the cab like on the
ROPS or even on the FEL arms is it attracts bugs like crazy.. Ideally, i would like to mount down low or up high on the grill to see around the bucket. anyone have any pics?
/ Mounting Auxiliary Lights #15
Two at cab top front, two rear, two low in grille and two cubes in the loader support tubes. Good to operate 24/7. With the cab the bugs don't matter. I have had open station tractors and ROPS mounted lights were awful, between the bugs and the glare. I normally mow without the forward facing cab mounted lights. They make the hood too bright. The low grille mounted lights work very well by themselves.
/ Mounting Auxiliary Lights #16
Tractors have Roll Over Protective Structures for a reason and using any tractor with it folded is, in my view, an accident waiting to happen. Think I'd erect a shelter where you can park the unit with the ROPS up, not down.
All it takes is a second of chance and you could be maimed or dead. Just my opinion.
/ Mounting Auxiliary Lights #17
I mounted a ..?..12” LED light bar on the front brush guard of my L3450…an oldie. I used 3” magnets as I didn’t want to drill holes. To solve the problem of wiring and a switch, I disconnected the low beam feed and spliced that to my LED bar. If I ever want to go back to ‘stock’ all I have to do is ‘unplug and re connect’.
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
TAYLOR 24 BLADE OFFSET DISC HARROW (A63291)
TAYLOR 24 BLADE...
John Deere 4040 Tractor (A64047)
John Deere 4040...
4' FIELD CULTIVATOR (A63291)
4' FIELD...
