Mounting a sign
/ Mounting a sign #11
This sign is light, essentially any couple wheels and something as a 2x6 screwed to the bottom for a tounge will do, about a thousand ways to mount a sign. I have a couple versions of the one in this pic
/ Mounting a sign #12
Seems like some 3pt pins and a bit of welding rod and a torch should make anything work.
Soundguy
/ Mounting a sign #13
im in carry all group myself.
a cheep one thats extended, or some angle and a welder and you could easly weld up a platform to hold the sign (strap it to it)
/ Mounting a sign #14
HappyCPE said:
My feeble mind, when it encounters a problem like this, always goes to a carry-all. :) They're cheap and adaptable. You can make some kind of holder out of wood for the sign since it is much bigger than the carryall.
also kinda easy to mess around with.
2024 Linx 6'x14' Trailer (A60462)
2024 Linx 6'x14'...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
Giyi 32" Excavator Bucket (A60463)
Giyi 32" Excavator...
2013 Freightliner Forest River 390BH 39ft. Class A Motorhome (A59231)
2013 Freightliner...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
DSP 900 Balancer with Split Weight (A61307)
DSP 900 Balancer...
