Mounting a ball on my bucket?
   / Mounting a ball on my bucket? #11
I was going to mount a 2" receiver to my FEL so I could move trailers around. I figured I'd need to weld something. Instead, I fund the Titan Clamp on Bucket Hitch. Mounts just like my Hay Forks. Can add any size ball hitch I need. I already have all three sizes mounted on slide-in males.
   / Mounting a ball on my bucket? #12
I just welded 2" receivers on the FEL and box blade. I didn't want to drill it, and didn't want wrenches to change the ball size, plus a receiver will take a clevis, hook, pintle, vise, etc.
Most tongue weight I have empty is on about a 3000# equipment trailer at about 500#, and it has put a rear tire up on an angled turn on a grade in the past using the bucket. I make sure I'm in 4wd, and go as low & slow as possible, and always keep in mind that tongue weight is not a fixed factor, but varies with heights & angles
You know your machine & it's limits quick with a trailer, as with FEL use, so if it gets the back too light, you (hopefully) won't chance it.
If you have a welder, I'd go for the tube route.
   / Mounting a ball on my bucket? #13
Many good ideas out there to pick from.
What I did,
   / Mounting a ball on my bucket? #16
Years ago I bolted down an old step bumper 2 inch receiver to my bucket for such purposes...do they even make that style anymore?
2020 DRAGON ESP...
2017 Ford F-550 (A55973)
2017 Ford F-550...
30KW GENERATOR (A58214)
30KW GENERATOR...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
