Mounting a ball on my bucket?
   / Mounting a ball on my bucket? #11
I was going to mount a 2" receiver to my FEL so I could move trailers around. I figured I'd need to weld something. Instead, I fund the Titan Clamp on Bucket Hitch. Mounts just like my Hay Forks. Can add any size ball hitch I need. I already have all three sizes mounted on slide-in males.
   / Mounting a ball on my bucket? #12
I just welded 2" receivers on the FEL and box blade. I didn't want to drill it, and didn't want wrenches to change the ball size, plus a receiver will take a clevis, hook, pintle, vise, etc.
Most tongue weight I have empty is on about a 3000# equipment trailer at about 500#, and it has put a rear tire up on an angled turn on a grade in the past using the bucket. I make sure I'm in 4wd, and go as low & slow as possible, and always keep in mind that tongue weight is not a fixed factor, but varies with heights & angles
You know your machine & it's limits quick with a trailer, as with FEL use, so if it gets the back too light, you (hopefully) won't chance it.
If you have a welder, I'd go for the tube route.
   / Mounting a ball on my bucket? #13
Many good ideas out there to pick from.
What I did,
   / Mounting a ball on my bucket? #16
Years ago I bolted down an old step bumper 2 inch receiver to my bucket for such purposes...do they even make that style anymore?
2010 SHOP MADE WINDMILL TRAILER (A58214)
2010 SHOP MADE...
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
1608 (A57192)
1608 (A57192)
