most likely a controversial mod.
/ most likely a controversial mod. #41
I believe ROPS are designed to give the manufacturer a bit of defense in court, as mentioned by many before. I also believe that when manufactured there is little if any thought given to providing space for the operator to survive a complete roll over. The larger the tractor, the shorter the ROPS, by design, because of the added weight stress. It has to be shorter to survive the roll over. Again, with little or no concern for the operator. Here's 3 examples. When you look at the pictures imagine where the operator's upper body is going to be in an upside down situation with his lap belt on.
/ most likely a controversial mod. #42
My ROPS have a sticker on them that basically says that it isn't appropriate for my tractor. It has printed on it "Max GVW 3748 pounds". That is about the dry weight of my tractor. As it sits, my tractor is around 6500 without anything on the 3pt.
So many cite the testing that OEM ROPS undergo. Check your ROPS to see if they are really designed for the real max operating weight or even the normal operating weight of your tractor. I was surprised and disappointed with what I found :thumbdown:
/ most likely a controversial mod. #43
The best ROPS is a four point fastened system with a hard roof on it to make it FOPS. MY B26 fits easily in my 8 foot door at my shop and gives not only roll over protection but protection from falling objects which I like. I am not too worried about rolling over even if I do a bit of slope work, but I have had a few rotting limbs fall out of trees on to the FOPS which might have been bad had I not had the roof over my head. If it were a few inches too high to fit in my shop, then I would have no qualms in cutting it down to size but I would put in a heavy gauge insert at the cut, then weld it with full penetration weld with 7018 electrodes. It would be stronger than the original tubing at that point. I trust my welding abilities having done it as a ASME certified pressure piping welder for several years and never had a rejected weld from an Xray or visual inspection. Your welding ability may not be up to the task and only the person doing the task can make that decision.
Obviously I wouldn't advise a beginner welder to do this task.
Gary put it very well much better than I could. I have had enough experience building 3 backhoe buckets, hydraulic cylinders & a goose neck trailer to have confidence in my ability to weld the ROP. I still would have done it only hired a professional.
/ most likely a controversial mod. #45
Can anyone tell me how thick a aluminum falling object protection would be on my tractor if it’s attached to my rollover protection system
/ most likely a controversial mod. #47
What are you trying to protect yourself from? Also what tractor are you mounting it on? Aluminum will most likely have more deformation than a steel plate. If memory serves right its SAE J231 that regulates FOPS. Here are some photos of a FOPS test for a Hough H60 by Sims cab company in 1975. You can see how the entire cab collapsed. I know that this is more severe than you plan on encountering, but the forces of a falling object can be significant.
Also it would have been better to start your own thread rather than revive an 8 year old one.
/ most likely a controversial mod. #48
This reminds me that I really need to get that bolt out in order to fold mine up. It's never been up since I purchased it used. I need a 10' cheater bar I believe.
/ most likely a controversial mod. #49
My Kubota M6040 would only fit in my carport stalls with the ROB folded. So.....this was my answer.
/ most likely a controversial mod. #50
Do you wear your seatbelt? I don't. I think my tractor has one but I have never put it on - not once.
I wear mine 100%. I put it on before starting the engine even if I'm immediately going to get off and do other tasks while it warms up -- I've heard worrisome stories about vehicles moving unexpectedly, even a tractor flipping backwards in the barn when it unexpectedly lurched forward and hit some overhead obstacle. Plus, definitely, any time I intend to move the machine.
I figure that, once the rollover starts, I'll be too busy flying around, getting impaled on levers, and having my insides extruded, to go looking for the seatbelt ends or untangle anything.
IMHO being in this simple habit is nothing compared to what I might regret.
Life has enough risks when I am trying to work safely. I don't need to invite anything else.
/ most likely a controversial mod. #51
I use my seatbelt when I perceive a risk of rollover. It doesn't hurt or hinder operation and the last thing you want is ejection in a rollover.
This week I'll be mowing a new field. It's hilly with 2-3 ft of weeds, grass, and brush. You can bet I will be strapped in and packing for rattlesnakes. Protection is good (y)
I added a hard plate of aluminum to my ROPS.
/ most likely a controversial mod. #52
As far as the ROPS mod, the best ROPS is the one that you actually use.
Keep in mind that ROPS doesn't mean tumble protection. The design isn't to have the tractor rolling several times down a hill, or having it landing upside-down.
In general the ROPS is designed that if the tractor flops on its side, then it wont actually roll over.
I just bought a Landini. The ROPS is near the mid point of the tractor, in front of the operator. Unloaded, the engine is likely a bit heavier than the rear end, but that could change with an implement. Anyway, it makes me a bit squeamish without having the ROPS around my head, but I have to remind myself that the design is to make it simply flop over rather than rolling.
Anyway, that is the reason why the ROPS is always much higher than an operator's head. And, taking 6" off of the top of the ROPS could actually make a difference in its ability to protect from a complete roll over.
Would I make the OP's revision? I might if there was no choice between a shorter ROPS and no ROPS. Or if putting it up and down was terribly inconvenient, and I was operating the tractor in an unsafe fashion with the ROPS down.
As far as the Landini, I'm considering whether I want to keep the forward ROPS, or build it into a crude roll cage.
