Most efficient way to burn wood
   / Most efficient way to burn wood #41
I think one of their main advantages is to heat multi buildings at one station. The most efficient ones use maybe a little bit more wood as a wood stove sq footage ratio wise. The not so efficient ones can use double the wood. Other advantages is they are cleaner for the house environs in not only keeping the wood mess outside, but also not breathing in the particulate matter of a wood stove inside the house.
Boilers aren't for everybody, and there have been some badly made ones.
Depending on where you live, external boilers may be easier/cheaper to insure since combustion is external to the dwelling. Dual pipes are pre-insulated, all in one tube (think O pipe diameter), so are efficient and easy to install. They can be useful for retrofits, using a heat exchanger on a forced air setup, and not just radiant/slab heating. Useful for initial or primary domestic hot water heating. Ash is already out of the house; you don't haul wood inside.
Boilers don't make much $ sense for heating a small well insulated space. At the other end of things (space wise), they can make a lot of sense. Attractive in the Ag world, for heating greenhouses. They (Portage and Main) have a large setup for an external (to the boiler) hopper for wood chips, auger driven - for large scale operations that are already dealing with chipped wood, this can make sense.
Like tractors :) , we all have different needs and preferences when it comes to wood :thumbsup: .
Rgds, D.
Thanks Dan. It is very helpful to hear the story side of this endeavor as things can get complicated. Just last night one of the daughters came to visit. I told of her of our plans and you know what she said? "Dad you guys can't move, Twilight ( the horse she had from when she was 5 to 26) is buried here" I said "oh yeah so is Digger (first dog here), all the cats, Liz the chicken, Moe, Larry and Curly the 3 geese Digger eliminated over a two year period when they tried to peck him in the you know what, and all the rest of the 6 other dogs" How could I be so thoughtless.
Rgds, D.
True dat! (gosh I'm getting hipper)
We built our home in 2009 slab on grade then buried the front half so we could have a walk out finished basement. The lower back walls are concrete half way up then wood the rest of the foundation walls are full concrete 12" thick. The house was designed as a one floor two bedroom open floor plan ranch with 1442 sq. feet. In Mass. with our building codes you must us 2x6 construction to pass energy code, also r38 roof and r30 floor insulation. I did not insl. the floor as we planned to heat with wood from the walkout basement that way the heat radiates to the main floor. The first stove we had was my Dads Fisher from 1978 or so. It worked well but burned enough wood to heat two homes and we had to feed it all the time. This past fall we bought a Harman tl300 and retired the fisher to the barn we put up this fall. With the new stove we heated the house all this winter loading it at 5:30 in the morning then again at 4:30 in the afternoon. With the stove in the lower level it heats up the concrete floor and the walls and they give off heat well after the stove temp. has gone down. So far we have used 1 1/2 cords that's one third of what we were using in the old stove. I have propane as our backup heat and put in a Reni on demand water heater that works great . We bought 22 acres of mixed woodlands so we have all the wood in the backyard we will ever need. Good luck with your new home and have fun with the planning and building of it as Jane and I did.
Is wood your main heat source G? I also have my wood stove in the cellar and to this point (starting on the coldest days of Oct and 24/7 as winter settled in) I've used a bit over 4 cord to heat 2300 sq ft. I have to count the cellar sq footage as the stove is heating that as well so 3 floors total. My house is a poorly insulated log home.
   / Most efficient way to burn wood #45
Yes we heat basically with wood but have a 500 gal. Propan tank in the ground and forced hot air heat system set at 58% 24/7 that only comes on if we happen to not be around for more than 12 to 14 hours . Our total sq. footage is 2644 that's 1442 main floor and 1202 lower walkout floor were the wood stove is. I have a drop ceiling in the walkout area with heat vents in it for the lower zone heat that has never bin run as we have never needed it. But we did have it set up so it can be diverted to the main floor system and by running the blower only it would draw heat from lower level system and stove to the upper and heat that way but again have never used this as The house stays at around 72 lower and 68 main level just by the heat rising thru the floor and the open stairway no fans at all. Only thing is you can not get a co from the building dept. for a house with no insl. in the floor but being a General Contractor for more years than I wish to count and this being my own home it could be done. By the way this was house # 35 of this design that I have built Jane fell in love with it at a 55 and over sub. I was doing and asked if we could do one there but I am only 58 and did not want to be stuck with a bunch over 55 people that's why we bought the 22acres. :)
   / Most efficient way to burn wood #46
NOT true this is why i suggested a CAT stove. You basically cut the air back till it smolders, no visible flame on the wood. You will get secondaries that float around at the top of the firebox buring the gasses inside before the rest goes through the CATs to totally combust. If you have good DRY wood and healthy cats and know what your doing you better have that blower on high to get that heat out cause your CAT temps will soar, if i dont cut my air back enough fast enough you will aee 1800F easy on the CAT probe. there designed to burn with low air and do it with ZERO smoke out of the chimney.
So, with a proper design catalytic stove you could burn very hot and get real efficiency. :eek:
If the proper combustion air has to be cut back to maintain proper heat something's not being utilized to it's full extent and thus may not be as efficient as could be.
Too much combustion air is not good either.:)
Can some tell me why using outside combustion is considered efficient?:confused:
   / Most efficient way to burn wood #47
I agree fully. The "stoves" (if you want to call them that) that seem the most efficient are the one's that burn hot but retain the heat energy to give up later. They also weigh around 6000#. I also agree with the house being designed around the stove. Site orientation for solar gain, insulation and internal exhaust seem to be critical. I am also wondering about chimney design. Mass stoves have a long exhaust path extracting as much heat out of the exhaust as possible. Instead of creating this "mass" with the stove design which takes up a lot of floor space, why couldn't one create the mass with the internal chimney? The key here I believe is not to allow the exhaust gases to directly exit out the chimney but instead recirculate before expulsion. Draft might be tricky and I cannot picture this with a 15' tall chimney. With all the right combo's, one may need but a cord of wood all winter which I also cannot comprehend at this moment if wood is the main heat source for 7 months. This floor plan I'm looking at is 54'x32' which is only about a 1700 sq ft house. I love wood furnaces for their ability to convey radiant heat but as someone said, might be overkill.
You will do fine at choosing a system that works for you.:thumbsup:
   / Most efficient way to burn wood #48
to be efficient (using outside combustion air) a fireplace/stove must have glass doors etc...
Along with the gasses (smoke etc.) combustion air as well as the air that gets siphoned along with it...has to come from somewhere...if it's not coming from outside...it has to come from inside...meaning the fire will be sucking outside air in every crack and crevice around windows and doors (creating cold drafts (inside)....outside combustion air eliminates the cold outside air from being sucked into the house reducing the efficiency
   / Most efficient way to burn wood #49
I think Egon that is because outside air is cooler, denser, so it has more oxygen. I have never had expieranced this with a wood burner. But a gas or diesel engine will benefit from cooler air outside the engine compartment. Also guys, I know we are probly on the same playing field, someone may have metioned this also. But dry seasoned wood is always better. I see the problem with people around here trying to burn green wood, it just doesnt work well. I think that is why alot of people have trouble with smoke coming out of there outside boilers. Green just wont burn worth a hoot. LUTT
   / Most efficient way to burn wood #50
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
2015 Freightliner Sprinter 3500 Cargo Van (A55852)
2015 Freightliner...
Year: 2013 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage 117,223: Plate: Body (A55852)
Year: 2013 Make...
30pc. 16ft.x 3ft. Black Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
