More Road questions and advice needed
   / More Road questions and advice needed #11
Soundguy, We call it "tar & chip" around here when they apply the liquid asphalt to the road and cover it with stone. But the stone has no "fines" in it. I don't think using it with the grindings would work very well. Usually it's sprayed over a gravel road then a thin layer 3/4" or so stone is wind rowed over it. Then they spray that and add a 1/2" or smaller stone over it. Sometimes it is done with 3 layers. Like I mentioned in an earlier post, if the grindings get a lot of direct sunshine, it will bond together on its own. We had a stockpile of it at out yard and if it sat for long periods in the summer, it would for a crust on it that was difficult to break through.
Jeff
You don't have to go thru the song and dance.. I'm a civil engineer.. I build roads...
you'd be surprised what a lil extra bituminous material does to lean millings.. actually.. do whatever you want to do.. i'll keep my opinions to myself. ;)
soundguy
   / More Road questions and advice needed #12
soundguy
I'm sorry if I offended you, that was not my intention.:( Sometimes I go a little overboard with my opinions regarding asphalt related info because that's about the only area that I consider myself knowledgeable Usually I am seeking the help of others for other issues and I am just trying to give back a little. I will try to be more articulate in the future.
I reread your post regarding putting the grindings down in layers with the tack coat between them, I think I misread it yesterday and thought that you were suggesting adding the liquid to the grindings and then grading it out, which wouldn't work very well, that's why I was explaining the process. I will also try to read others posts more carefully before responding in the future too.:eek:
Jeff
Again, I
2016 Audi A3 AWD Sedan (A56859)
2016 Audi A3 AWD...
2025 Yakta YXR610 Zero Turn Lawnmower (A57453)
2025 Yakta YXR610...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
125 Gallon Water Tank (A57454)
125 Gallon Water...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
