More Noob Questions,,,,,,,,,,
/ More Noob Questions,,,,,,,,,, #1
gltrap54
Topeka,KS
B3200 Kubota
My B7500 is equipped with R4 tires, a FEL, 54" MMM, and a 48" BB. My question is: What attachments can/should be left on when I'm using the tractor to mow my lawn?
/ More Noob Questions,,,,,,,,,, #2
The less weight on the tractor the better when mowing, so I would remove the FEL and the BB. I have R-4's and i find that they are fairly gentle on the lawn - but it is best to lighten your load to reduce rutting. The additional problem with the FEL is that I tend to get more bounce/jostle with it on.
/ More Noob Questions,,,,,,,,,, #3
agreed. the only other comment i would make is that i sometimes loose a little traction in the front when turning. my bx is designed for the loader in front, so with it off, it gets a little heavy to the rear (especially when the rear tires bite) and i noticed my r-4s will slide a bit in tight turns. getting just the right amount of weight on the front bumper helps the tires bite better, but generally you want as little weight on the entire machine as possible to avoid compaction of the sod and the bouncing mentioned by the previous poster.
amp
I appreciate your input. The MMM by it's self seemed logical, but I wasn't sure.
JMR Tree Boom Mini Skid Steer Attachment (A64553)
JMR Tree Boom Mini...
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
Ford Model 8N Tractor (A66285)
Ford Model 8N...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
