Montana power lever
/ Montana power lever #1
bossrat
I have a Montana 49 HP. The lever that gives it the gas does not stay in place when released. How do I fix it.
/ Montana power lever #2
I have a friend with the 4940, I might have to take a look at his. Most of them have a nut you can tighten under the dash that will hold the throttle in place. They usally have a rubber/plastic bushing of sorts. I've had an older case that would gradually slip down rpms on rougher ground till I tighten that bolt some.
Good Luck,
Not sure that helped.
/ Montana power lever #3
Just to clarify are you talking about the foot pedal or the hand lever?
2023 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2023 CATERPILLAR...
12ft. Flatbed Truck Body (A59230)
12ft. Flatbed...
Wanco NTCIP Towable Solar Message Board (A59228)
Wanco NTCIP...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2018 FREIGHTLINER...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
