modifying a disk by adding a plow
/ modifying a disk by adding a plow #1
HogSlayer6
MO/KS/AR
Case 930, Ford 1900 and 8N
Has anyone ever seen or heard about a 3pt attachment that is a set of 2 or 3 bottom plows on one side and flip it over and its a set of disks? I have seen both plows and disks with wheel sets that you can set the depth with or use when transporting them but a fellow told me about a plow/disk combo he had seen awhile back. If you have any info or pictures on something like this I would like to hear from your. I don't really want to weld anything to the back of my 3btm plow so I am looking for something lighter to weld a set of disks to I guess. Thanks Hog
/ modifying a disk by adding a plow #2
Never seen or heard of that type of deal before. Maybe it was a backyard monster?
jb
/ modifying a disk by adding a plow #3
Interesting. Never seen one with shares on one side and disks on the other. Rollover plows as they're called have plow shares on both top and bottom. When you get to the end of the field, the plow "rolled over" and you could go back down the same furrow you just came up. They were somewhat popular in certain parts of the country.
Pretty sure IH made them. Maybe JD. Probably others.
This is what they look like.
/ modifying a disk by adding a plow #4
Hog slayer, saw your question right after you posted it and will join in with have never seen such in farm use. If 3 pth how would it roll over and not be to large and heavy?
/ modifying a disk by adding a plow #5
Won't work for the simple reason that you wouldn't be able to lift it up high enough to flip it over and not hit the ground.
/ modifying a disk by adding a plow #6
I have seen plows on both sides. when you turn them over you can turn around and plow back the other direction. That disk you are talking about looks like a plow that uses a large disk insted of a molboard I have seen several like that but never both types on the same plow..........Larry
2019 C&M TRAILER 18' T/A UTILITY TRAILER (A63569)
2019 C&M TRAILER...
karcher pressure washer (A61567)
karcher pressure...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
2019 KOMATSU WA320-8 WHEEL LOADER (A64279)
2019 KOMATSU...
MOBILE HOUSE SKID (A63569)
MOBILE HOUSE SKID...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
