Modified King Kutter Carryall
/ Modified King Kutter Carryall #1
Runner
Elite Member
Missouri
2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
I finally got around to setting up my KK carryall this week. I added a receiver hitch, cut down from one off a junked car. I used treated 2x12's cut 5 feet long for the floor and back. A little JD green and it was good to go. One problem, the height of the back panel makes it impossible to see the corners from the operator's station whcih makes maneuvering difficult.
Later, I plan on adding sideboards and a bench seat.
/ Modified King Kutter Carryall #2
That looks good Runner. Once you get the seat and sideboards installed, you can tow a small float in a local parade with pretty girls waving from your carryall with more pretty girls waving from the float.
This is the only modification I've made to my KK carryall. Picasa Web Albums - Matt - King Kutter K...
Matt,
I think the wife will be the only pretty girl waving from the carryall....
The main reason for the trailer hitch is that this will be my tree-trimming rig. I have an electric pole saw, so the generator goes on the carryall. I'll have my utility trailer on the hitch to throw the tree limbs in while I'm working, so theoretically, I just make one trip around the property.
Your brackets look great. I can only aspire to someday be able to do metalworking of that quality, but I'm afraid that day may never come.
/ Modified King Kutter Carryall #4
I just bought a carry all for the same reason Runner. I'm wondering if you will have to tie it to the drawbar when you are towing the trailer to keep it from rising up if the trailer load gets a bit to the rear, etc. I've thought about putting a trailer hitch on my chipper for the same reason.
/ Modified King Kutter Carryall #5
Runner,
Nice job, I need me one.
/ Modified King Kutter Carryall #6
I finally got around to setting up my KK carryall this week. back panel makes it impossible to see the corners from the operator's station whcih makes maneuvering difficult.
Not as elaborate as yours but it serves my purpose.
LB,
Your carryall looks great. The "curb" around it is great for keeping your cargo from sliding off.
Chuck,
I anticipated the possible upward movement of the carryall with the hitch on it. The adapter between the hitch and the carryall has a chain with a "D" link attached to it to prevent this. If you look real close, you can see it in the blow up picture attached, although it wasn't hooked up to the drawbar for the picture.
/ Modified King Kutter Carryall #8
Matt,
Thanks Runner concerning the brackets. It sounds like you have a good plan in mind for saving yourself some trips.
/ Modified King Kutter Carryall #9
Ah, I see that D ring now. That is a good plan, and I think I'll use it on mine. I have to check the pre drilled hole spacing, and see what I have for lumber then I'll get mine set up.
/ Modified King Kutter Carryall #10
Those Wilson Outdoor videos are a hoot to watch. I especially like the tool holders on the carryall.
Their other videos ar fun too, like the ones on hay production, etc.
Thanks for the link.
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2007 FRAC TANK 500BBL WHEELED (A63569)
2007 FRAC TANK...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
