Backhoe Model # location ford 555 backhoe
/ Model # location ford 555 backhoe #1
Poppa K
Jackson tn
83 model Ford 555 loader/backhoe and a 255 Massey Ferguson tractor
Hey new to site
I have a ford 555 loader/backhoe and need to know how to find model # of hoe. Only numbers I've found are behind the starter on transmission.any help will be appreciated.
DF511F
8E5B
C702444
/ Model # location ford 555 backhoe #2
Welcome to TBN. I'm not in my shop right now but will post details of how to read the numbers when I get back there.
Is there a tag on the side of the dash tower, entry side. Should be eye level when standing beside machine facing dash. Mine is a stenciled black and silver tag about 2x3 inches. Lists tractor number, model, unit, engine, transmission and rear axle. With the unit number I can tell you everything including what shift built it.
Maybe post some pics of your machine?
/ Model # location ford 555 backhoe #3
DF511F is your Model number
DF5 = 555 industrial flat deck
1 = Diesel engine
1 = no lift or PTO
F = 4x4 torque converter auto reversing transmission
8E5B is your assembly date May 5, 1978 second shift
as for the Hoe itself, the 555 was available with either a 14' or 15' reach backhoe, there is a Ford
component tag on the main mounting frame of the hoe, number should begin 19-XXX that can tell us which it is
/ Model # location ford 555 backhoe #4
Good stuff Joe!!!
The hoe tag should be on the subframe, left side, rear.
I gather all these numbers and create a file. If going for parts I have all that with me.
Thank you both I will look and see if I see any more #'s. Yall are a big help
Think I'm gonna like this site if I ever figure it all out.
/ Model # location ford 555 backhoe #6
You're welcome.
Keep us updated on your progress.
Have a # 19-608 on tag of backhoe if that means anything ?
/ Model # location ford 555 backhoe #8
this is on the backhoe itself on the main swing frame?
might want to re-check that a bit closer, that's for the front loader on an older machine
(19-608) - BUCKET, H.D. MATERIAL, 1 YD., 740 SERIES (EXCEPT U.S.) (1/71-12/75)
Well dang that's the only tag I saw back by the hoe. Any other particular place it might be ? Still haven't located a switch yet local so may have to order online. Any idea if fuel lines to pump have an original where they connect or are they flared. Have one leaking and lost my prime. But gotta get switch fixed first just wondering ?
Meant o-ring not original
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2017 Kia Cadenza Sedan (A61574)
2017 Kia Cadenza...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
