MMM storage during winter
/ MMM storage during winter #21
Larry's wheels are great and a must have if you have a MMM. It makes working on the deck very easy and safe. The only down side is you need a hard surface to roll the MMM on. I have had my wheels for many years with no problems. Larry was great to work with fast processing of my order.
/ MMM storage during winter #22
Exactly the same as psvines.
BTW, there's a trick to slackening the belt, I learned it from one of the posters here...use a long bar and lever it against the idler pulley then slip the belt off one of the other pulleys.
/ MMM storage during winter #23
Pressure wash. Undercoat with ff. Lean against wall till spring.
/ MMM storage during winter #26
using some 4 inch casters from h-f and some 2 hole pipe straps, i think i can make some 'steverino wheels' for about 20 to 30 bucks. i'm sure the larrie ones are nice,
but for the few times these are needed i can't justify 100 dollars. btw, 2 triangle mover's dollies at h-f is about 8 dollars, so larrie has some serious markup on those as well.
/ MMM storage during winter #27
Larrys wheel kit, clean the underneath, sharpen blades and grease spindles, light coat of wd-40 or FF if you can find it, store inside along garage wall. Treat the shaft the same way!
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
John Deere 5M Series Tractor Loader Frames (A65640)
John Deere 5M...
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2023 UTILITY VS2RA...
