MMM storage during winter
/ MMM storage during winter #21
Larry's wheels are great and a must have if you have a MMM. It makes working on the deck very easy and safe. The only down side is you need a hard surface to roll the MMM on. I have had my wheels for many years with no problems. Larry was great to work with fast processing of my order.
/ MMM storage during winter #22
Exactly the same as psvines.
BTW, there's a trick to slackening the belt, I learned it from one of the posters here...use a long bar and lever it against the idler pulley then slip the belt off one of the other pulleys.
/ MMM storage during winter #23
Pressure wash. Undercoat with ff. Lean against wall till spring.
/ MMM storage during winter #26
using some 4 inch casters from h-f and some 2 hole pipe straps, i think i can make some 'steverino wheels' for about 20 to 30 bucks. i'm sure the larrie ones are nice,
but for the few times these are needed i can't justify 100 dollars. btw, 2 triangle mover's dollies at h-f is about 8 dollars, so larrie has some serious markup on those as well.
/ MMM storage during winter #27
Larrys wheel kit, clean the underneath, sharpen blades and grease spindles, light coat of wd-40 or FF if you can find it, store inside along garage wall. Treat the shaft the same way!
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
2022 EZ-GO ELITE...
2003 Coleman Pop Up Camper (A62613)
2003 Coleman Pop...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2yd. Skid Steer Trash Hopper (A65640)
2yd. Skid Steer...
C&S FARMS AUCTION - IN LOVING MEMORY OF JACKSON STRICKLAND. (A64277)
C&S FARMS AUCTION...
