Oil & Fuel Mitsubishi or Satoh ?
   / Mitsubishi or Satoh ? #31
I can kinda picture what you are talking about, But still can't help with problem. I do know that the control knob that is in the middle is to control the speed that the 3 pt hitch lowers. See if the attachment helps.
  • Flow control.pdf
   / Mitsubishi or Satoh ? #32
Thanx. That is the lever I was mentioning about. Now it makes sense after reading it. I thought it was an implement control of sorts and its not. More of a control on the lowering/release of fluid. Also, will PM you my cell phone number in case you think of anything else that may help, be pertinent or you need pics as going out to the shop to look/work on this thing. Thanx again Larry as we will be experts before we know it!!!
Finally found out a little more about my tractor than when I started this thread. Bill at Valley was a great help and explained to me that my S650 is a setup that he's only seen once before because it has the KE 130 diesel instead of the gas engine. Either someone replaced the engine with the S630 diesel or maybe they made a few that way but the other one he saw has a completely different number series. My luck to buy a mixture of parts. Bill told me that I could use the S650 manuals for the tractor and S630 manuals for the engine. He has them all available. I'm getting one of each for both models, 6 manuals total. Guess I'm gonna start a heck of a library. Would like to thank everybody for all the responses and info, I feel about 10% less dumber about this tractor than when I started.
   / Mitsubishi or Satoh ? #34
Here is what I found in my instruction book Page 1 and 2 are the capacities and are duplicated. Page 3 is the types. And page 4 is the how to on the transmission and hydraulic oils. Hope this helps Ya'll.
Great info! Thanks for sharing!
   / Mitsubishi or Satoh ? #35
I had no idea what that lever did either before... The guy I got my tractor from didn't know that much about it either.
2014 NISSAN NV CARGO VAN (A59575)
2014 NISSAN NV...
24in pin on tooth excavator bucket (A56436)
24in pin on tooth...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
