Mitsubishi Hydraulic Problem
   / Mitsubishi Hydraulic Problem #1
Justdoc
misubishi mt250d
I need help in figuring out how to change the hydraulic oil in my
Mitsubishi MT 250 D tractor. I am sure there is a drain plug but
I cannot find it. Thanks for the help.
DOC
   / Mitsubishi Hydraulic Problem #2
I'm quite sure there should be a drain for it somewhere....just keep lookin'....it should be underneath...could be a sqaure type plug or hexigon....(excuse my spellin') Ampa
   / Mitsubishi Hydraulic Problem #3
It has been several years since I owned a 250 so I can not recall the exact location, however if you look under the transmission case there should be a plug ( probably in the side of the case..not the bottom). They are usually a 4 sided plug head and it will be near the lowest part of the trans case. On my MTE2000D it is on the right hand side ( sitting on the tractor).
If you don't have a manual , GET ONE! The I&T Shop Manual for Mitsubishi MT160-300 series are cheap, available many places online and indispensable for any Mitsubishi owner.
Thanks for the info. I posted looking for a place I can download the manual
Justdoc
   / Mitsubishi Hydraulic Problem #5
Just google " I&T Mitsubishi shop manual MT160-MT300 " and a number of suppliers will come up. They are not "every single detail" specific but they cover a lot of needed info for any owner and the MT250 is cover specifically in it. I looked in mine and it did not give the exact location for the Hyd. fluid drain plug but gave all other details for fluid changes.
   / Mitsubishi Hydraulic Problem #6
On my tractor.....I found it on the bottom....infact there were two drain plugs....of course
I own a greymarket tractor... maybe a different animal altogether....Ampa
   / Mitsubishi Hydraulic Problem #7
I checked the manual and it does not show the drain plug.Hydraulic oil capacity for your model is 21qts and your filter is located in the suction pipe.If you still need a manual I have one I don't need.Pm me your address and mail it to you.
Thank you all, I found the plug and took care of the problem.
Justdoc
NEW Woods 6ft Finish Mower (A53473)
NEW Woods 6ft...
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
backhoe attachment for mini skid steer (A53421)
backhoe attachment...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
1997 STOUGHTON TRAILER DRYVAN (A53843)
1997 STOUGHTON...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
