Mitsubishi Hydraulic Problem
   / Mitsubishi Hydraulic Problem #1
Justdoc
misubishi mt250d
I need help in figuring out how to change the hydraulic oil in my
Mitsubishi MT 250 D tractor. I am sure there is a drain plug but
I cannot find it. Thanks for the help.
DOC
   / Mitsubishi Hydraulic Problem #2
I'm quite sure there should be a drain for it somewhere....just keep lookin'....it should be underneath...could be a sqaure type plug or hexigon....(excuse my spellin') Ampa
   / Mitsubishi Hydraulic Problem #3
It has been several years since I owned a 250 so I can not recall the exact location, however if you look under the transmission case there should be a plug ( probably in the side of the case..not the bottom). They are usually a 4 sided plug head and it will be near the lowest part of the trans case. On my MTE2000D it is on the right hand side ( sitting on the tractor).
If you don't have a manual , GET ONE! The I&T Shop Manual for Mitsubishi MT160-300 series are cheap, available many places online and indispensable for any Mitsubishi owner.
Thanks for the info. I posted looking for a place I can download the manual
Justdoc
   / Mitsubishi Hydraulic Problem #5
Just google " I&T Mitsubishi shop manual MT160-MT300 " and a number of suppliers will come up. They are not "every single detail" specific but they cover a lot of needed info for any owner and the MT250 is cover specifically in it. I looked in mine and it did not give the exact location for the Hyd. fluid drain plug but gave all other details for fluid changes.
   / Mitsubishi Hydraulic Problem #6
On my tractor.....I found it on the bottom....infact there were two drain plugs....of course
I own a greymarket tractor... maybe a different animal altogether....Ampa
   / Mitsubishi Hydraulic Problem #7
I checked the manual and it does not show the drain plug.Hydraulic oil capacity for your model is 21qts and your filter is located in the suction pipe.If you still need a manual I have one I don't need.Pm me your address and mail it to you.
Thank you all, I found the plug and took care of the problem.
Justdoc
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
Ingersoll-Rand Winch (A53117)
Ingersoll-Rand...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
