Hi folks,
I have a grey market Mitsubishi D1800 (II) with a KE95 engine. I haven't checked compression yet, but it starts right up and runs just fine, up to about 1700-1800 rpm, where it starts to bog and spit white smoke. Both cylinders doing it. When I bring it back down to about 1500 rpm, all is well. Idles all the way down to 500 rpm. Starts quickly and runs great, up to that point, and it'll run all day like that. I pushed it once just to see if I can get past a "bad spot" and nothing changes, but I throttle it back to around 1500, and she just hums. I just replaced the head and gasket (new valve job) a week or so ago, re-torqued just today. Injectors both crack at about 1600-1700 psi and give a nice chatter and mist. No leaks, no change with / without air filter, just did the overhead at .013... I'm kinda stumped. Normally I'd say new injectors, but these look perfect. Any thoughts?
