mitsu duals
/ mitsu duals #11
I think AKFISH built dual for his tractor so he could operate in in soft dry sand. He would be the go to guy for this.
/ mitsu duals #12
Case on thee things has quite a bit of aluminum in them. Guess it depends what you plan to do, for just general driving I wouldnt have any worries but if your driving thoguh uneven terrain where you loading hte outer tire, is that much longer of a lever arm on the tranny your putting the force through.
/ mitsu duals #13
Techwrtr2, what exactly have you broken on your Satoh, and what is the failure mechanism? Is it breaking in normal usage?
I'm not sure I'd consider a lot of our usage over the years as "normal". It's been a long time since I broke one of the bolts out back, I don't recall exactly how. I'm sure some of it was connected to removing the 3pt hitch parts and installing the saddle for our backhoe that contributed. I no longer do that since I have another tractor.
I've broken the frame up front a number of times but that was due to hard use/abuse more than anything. Ever since plating the areas and taking more care, I have broken nothing.
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2009 Ford Ranger 4x4 Ext. Cab Pickup Truck (A59230)
2009 Ford Ranger...
iDrive TDS-2010H...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Kubota LX2620 (A53317)
