Miter Saws
/ Miter Saws #41
You can track down a miter saw off craigslist easy peazy, maybe upgrade the blade if need be. I have an old 10" Delta Shopmaster, did a lot with it, include framing the interior walls of my hunting place. Did the baseboards of my current 2 story house with a finished basement. Added a 12" sliding compound Ryobi to the mix. A good stand is essential. I have a finish blade on the big saw, and just construction blade on the small saw.
/ Miter Saws #42
I got mine via menards for just over $300. They go on sales at Home Depot, but I never saw it that cheap at those stores.
The 12" Cruzer sliding compound miter saw? Never seen it that cheap at Menards or anywhere. Must have been a rare deal. $499 is the cheapest I found in the past 6 months, with 11% rebate from Menards or HD.
Rob
/ Miter Saws #43
I have about a 10 year old Hitachi 12" sliding compound miter saw that I mounted on a Bosch foldable stand that I love. I am confused on Metabo and Hitachi going forward. I do not know if they merged or what. I bought a framing nailer and an electric drill from Metabo thinking they were Hitachi per the advertisements. Quality is great but batteries and chargers are different. Same voltage. WTF?
/ Miter Saws #44
Now that the OP has bought a saw, I do not feel like I am hi jacking the thread. What is the best general purpose miter saw that will not break the bank?
I bought a 12” Dewalt sliding saw last summer to replace an old Craftsman saw. I am very pleased with the saw. It came with a cheap contractors blade which I never installed. I instead bought and installed a carbide Harbor Freight blade. It is the blue blade. I think I paid about $30 for it.
I have used the blade to install trim, shelving, ship ladder, etc for our entire cabin. I also have built two workbenches at the cabin using this blade as well as just general cutting. The blade has been really good until last night. I had a little trim left to finish up the loft and the blade seemed very dull. It just did not cut as well as it has been cutting.
Two weeks ago I used the saw to install laminate flooring in the loft and I suppose that dulled the blade. I just need a blade for general construction and trim work, no fine wood working.
My next project is a privacy fence at our house which the original Dewalt blade will work for but I would like to get another good all around blade. Recommendations appreciated.
/ Miter Saws #45
Dewalt has a DEWALT Construction 12-in 60-Tooth Tungsten Carbide-Tipped Steel Miter Saw Blade
Amazon $40.00 free shipping
/ Miter Saws #46
Years back I bough for 50 bucks radial arm saw made by Sears. It does everything miter saw will do and more.
/ Miter Saws #47
I can pick my miter saw up with 1 hand.
Put it in the back of the truck
Take it into a house
set it up outside. etc
but would love to have a radial arm saw...if I had the room
/ Miter Saws #48
Radial arm saws are great but take valuable floor space. A friend offered me a free older Craftsman radial arm saw last week. He had the saw stored in a shed at a house that he has been renting out. He is selling the house and getting his stuff out of the shed and does not want the saw in his current shop.
/ Miter Saws #49
I sold my last radial arm saw about 2 weeks after I bought my first sliding miter saw. About 30 years ago. Never thought about it again.
/ Miter Saws #50
There was a recall on radial saw due to high number of injuries. If you get one, check with Sears using the serial number. I got new table and redesigned blade cover for free.
/ Miter Saws #51
I have done a lot of DIY work, built 5 houses and renovations for many years.
The only injury I ever sustained from power tools was a from a radial arm saw.
And from the original De Walt built like an armored truck. All cast iron structure and heavy.
I was ripping a board and the saw grabbed it and drove it into my rib cage and bruised me.
Being 'bit once' I then always stood off to the side but again it grabbed a board and drove it across the room.
Ripping sure was not their strong point.
Sold it!
Bought a good chop saw and HD table saw instead.
Yes, recalls on some more cheaply made versions, many of which used a bent aluminum like structure.
Added is that accurate set up for precise work is almost impossible.
My De Walt came from a picture frame shop that never ever was able to make a decent 45 deg cut for framing. (and I tried also)
/ Miter Saws
This is me also. Was moving to a smaller house/property and just did not have the room for the radial arm saw. Tried to sell it, but there was a glut of them on Craigs List, so it was recycled!
/ Miter Saws #53
I have the shop space if anyone wants to offload an old-school radial arm saw! :) Promise I'll give it a good home.
/ Miter Saws #54
You say occasional use. I bought a HF 10'' compound slide about 15 years ago. Cheapest one they made.
I built a den and cut all the trim for it. I have cut I don't know how many 4x4 post for fencing. I have really been impressed.
Using this thing around the farm, I never expected it to last this long. Especially cutting as many 4x4 post as I have.
It doesn't have a large enough stop /fence ? to be able to cut crown molding. But I don't expect to be cutting any
/ Miter Saws #55
Lucky me.
My current radial is a Makita, 12 inch slider that cuts 4 x 4's left or right @ 45 deg's.
Even has a laser to aim. (never use it)
I was a swap as a friend wanted my earlier Makita 10 inch as it was more compact.
Due to weird circumstances, (like right time right place), my total investment is actually $200. all told, both saws.
Blades came next. 12" aren't given away, but on a liquidation table I got a nice 12' finishing blade with one tooth knocked off, clerk dropped it!---$$12.00!
Most miter saws are cast from white metal, not aluminum.
One must be very careful lugging them from and to job sites.
I went so far as to custom build a plywood carry tote 'box' to protect mine in transit.
You never know, bumping down a country road anything can fall off of an upper shelf and put that saw out of alignment.
After some 12 years of contracting it remained as accurate as when new.
