Mistake????
/ Mistake???? #1
Lunk
Platinum Member
WI
Branson 4720H / BL200 Loader
Starting to think that maybe I should of kept my Branson 3510i.
Hydraulic fitting broke 10 days ago under seat, resulting in about 2 gallons of fluid loss, and a bunch of dead grass. Called dealer and texted pics of leaking fitting. Dealer promised to get parts on the way, and I agreed to replace it myself since I am 50 miles away.
10 days now, and the Dealer is telling me that TYM is being unresponsive in getting him the part(s).
I love the performance of the TYM vs. my old Branson, but 2 major failures (other was orbital valve for steering at around 60 hrs.) in under 90 hrs. has me thinking for sure!
At this point feeling a bit perturbed.
Lunk
/ Mistake???? #2
I'm afraid to use my 233 since warranty ran out.If I can find parts,I can't afford them.
/ Mistake???? #3
Well... sorry to hear that. How did that happen?
/ Mistake???? #4
I thought TYM was trying to improve their parts division. I am guessing one of the rear remote coupler broke. I would not write the entire tractor off for a $50 fitting. All tractor brands have problems. From what I hear Branson is worse to get parts from.
/ Mistake????
Sorry I've been out.
Working 7 days/week right now, and I'm beat.
It's leaking from a fitting up under seat area, where a hard line enters via a 90 degree elbow from the hyd block under the Front right of the floor. I removed the line, and there's no noticeable damage... May need to pull the elbow...
Fitting was tight (used line wrench to verify...). Leak was pretty severe. Amount was like a stream of syrup when you're topping your Pancakes. Luckily I noticed it as I was on the ground chucking rocks into the bucket. If I'd been brush-hogging trails I would have drained it before noticing...as it is I lost a couple gallons. Stuff is effective at killing grass for sure.
I've heard Branson horror stories too, but nothing broke on mine in the 370 hours I owned it...
Other than these issues, I find the tractor superior in capability.
Lunk
/ Mistake????
Tomorrow afternoon I'm taking the parts to the dealer, who said that he'd pull them from an in-stock unit if he could to help...
/ Mistake???? #7
Our TYM has about 1000 hours on it. It had a fuel leak when it was new which took only minutes to fix. It never saw a dealer or needed a part except persistent leak from sight window on the transmission. I replaced it three times already. It will be OK for some time and then it will start leaking again. I tried to glue it, seal it but so far with little success. Beside that it is a workhorse.
/ Mistake???? #9
3 yr bumper to bumper-good thing almost 1/3 of it was down time.then drivetrain for 2 stepping down to only parts the 5th year.
/ Mistake????
Tractor is fixed!
After talking to the dealer (again), he suggested that I save the 100+ mile round-trip and have the line replaced with a locally made hydraulic hose, which he'd reimburse me for.
Worked like a charm, and my tractor is back at work.
All is good again in my world...
/ Mistake???? #11
That's great news and great that he stepped up and is paying for it.
/ Mistake???? #12
try shoo goo or automotive goop. Silicone with glue. Good stuff. Obviously make sure the surfaces are clean and dry. I usually use alcohol to clean first...
/ Mistake???? #14
I am truly impressed with these "goo" products. I bet that will work, as long as your surfaces are clean,clean,clean and dry. You'll probably have to drain the fluid down first.....
/ Mistake???? #15
I just put the tractor nose down slope to drop the level below the sight window.
/ Mistake???? #16
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
CAT 963C Multi-Shank Ripper (A68134)
CAT 963C...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
2008 Generac SD100 T3 125kVA Standby Diesel Generator (A66734)
2008 Generac SD100...
8ft Fork Extensions (A66734)
8ft Fork...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
