Mistake????
/ Mistake???? #1
Lunk
WI
Branson 4720H / BL200 Loader
Starting to think that maybe I should of kept my Branson 3510i.
Hydraulic fitting broke 10 days ago under seat, resulting in about 2 gallons of fluid loss, and a bunch of dead grass. Called dealer and texted pics of leaking fitting. Dealer promised to get parts on the way, and I agreed to replace it myself since I am 50 miles away.
10 days now, and the Dealer is telling me that TYM is being unresponsive in getting him the part(s).
I love the performance of the TYM vs. my old Branson, but 2 major failures (other was orbital valve for steering at around 60 hrs.) in under 90 hrs. has me thinking for sure!
At this point feeling a bit perturbed.
Lunk
/ Mistake???? #2
I'm afraid to use my 233 since warranty ran out.If I can find parts,I can't afford them.
/ Mistake???? #3
Well... sorry to hear that. How did that happen?
/ Mistake???? #4
I thought TYM was trying to improve their parts division. I am guessing one of the rear remote coupler broke. I would not write the entire tractor off for a $50 fitting. All tractor brands have problems. From what I hear Branson is worse to get parts from.
/ Mistake????
Sorry I've been out.
Working 7 days/week right now, and I'm beat.
It's leaking from a fitting up under seat area, where a hard line enters via a 90 degree elbow from the hyd block under the Front right of the floor. I removed the line, and there's no noticeable damage... May need to pull the elbow...
Fitting was tight (used line wrench to verify...). Leak was pretty severe. Amount was like a stream of syrup when you're topping your Pancakes. Luckily I noticed it as I was on the ground chucking rocks into the bucket. If I'd been brush-hogging trails I would have drained it before noticing...as it is I lost a couple gallons. Stuff is effective at killing grass for sure.
I've heard Branson horror stories too, but nothing broke on mine in the 370 hours I owned it...
Other than these issues, I find the tractor superior in capability.
Lunk
/ Mistake????
Tomorrow afternoon I'm taking the parts to the dealer, who said that he'd pull them from an in-stock unit if he could to help...
/ Mistake???? #7
Our TYM has about 1000 hours on it. It had a fuel leak when it was new which took only minutes to fix. It never saw a dealer or needed a part except persistent leak from sight window on the transmission. I replaced it three times already. It will be OK for some time and then it will start leaking again. I tried to glue it, seal it but so far with little success. Beside that it is a workhorse.
/ Mistake???? #9
3 yr bumper to bumper-good thing almost 1/3 of it was down time.then drivetrain for 2 stepping down to only parts the 5th year.
/ Mistake????
Tractor is fixed!
After talking to the dealer (again), he suggested that I save the 100+ mile round-trip and have the line replaced with a locally made hydraulic hose, which he'd reimburse me for.
Worked like a charm, and my tractor is back at work.
All is good again in my world...
/ Mistake???? #11
That's great news and great that he stepped up and is paying for it.
/ Mistake???? #12
try shoo goo or automotive goop. Silicone with glue. Good stuff. Obviously make sure the surfaces are clean and dry. I usually use alcohol to clean first...
/ Mistake???? #14
I am truly impressed with these "goo" products. I bet that will work, as long as your surfaces are clean,clean,clean and dry. You'll probably have to drain the fluid down first.....
/ Mistake???? #15
I just put the tractor nose down slope to drop the level below the sight window.
/ Mistake???? #16
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A64556)
2014 International...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
