3-Point Hitch Missing 3-Point Hitch Controls?
/ Missing 3-Point Hitch Controls? #1
Komrade
Western Morgan County, WV
Kubota L3430 HST
Still a newbie when it comes to tractors..
So, today I removed the backhoe and tried to attach the rear scape blade, that I previously restored (with some help).
I had my neighbor point out the missing parts (some pins were missing).. After running to the tractor store and starting attaching the three point arms, I started looking at my controls... and at my manual.. manual says I should have 3 point controls, but I don't appear to have them.. However, the cyliders are there, so something must operate them.. what am I missing?
1st: Front Bucket and "Remote" control (operates snow plow)
2nd: Shows the lever is switched towards the "Remote" control (you can either use the backhoe, or "Remote")
3rd: 3point pitch and PTO controls are supposed to be here
4th: gears and speed control (never used the latter)
5th: 3 point hitch related (controls speed, per manual)
6th: pedals :)
Here's a view of the back.
/ Missing 3-Point Hitch Controls? #3
I don't know your tractor, but the lever in the third picture looks like the 3PH position control lever to me.
Steve
/ Missing 3-Point Hitch Controls? #4
It's the big lever to the right of the seat with numbers/positions 0-8 on the scale.
It seems to do nothing. Almost if something needs to be switched on to let it engage.
/ Missing 3-Point Hitch Controls? #6
Is it a factory backhoe? You may need to connect the two backhoe hoses together in order to complete the power beyond (PB) loop that goes to the 3-pt hitch. That is always last in the PB loop on Kubotas.
I do see some non-factory valves in your pictures, so it's possible you don't have a standard PB setup anymore, if someone modified the loop thinking the backhoe was permanent....
The backhoe is Woods 9000.
The backhoe hoses were connected.
Where do you see non-factory valves.. could they be for the snow plow?
Going to go check if 3point speed knob is all the way "open" (thought I tried it.)
/ Missing 3-Point Hitch Controls? #8
The exposed valve on the fender is definitely not factory.
Question -- what is on the hose that runs from that valve and goes under the loader valve mount -- looks almost like a bronze or brass ball valve with the lever cut off? I hope it's not a bronze or brass ball valve on a hydraulic system, as they aren't normally able to handle pressure that high.
That valve controls if I can use the backhoe or the snow plow. I do not know what it is made from.
The issue was with the 3point speed knob. Once I put it to open things started to work.
Wanted to thank folks in this thread, as well as other helpful threads I participated in or just read (for tips on using blade and bucket to level the gravel)
I was able to fix all the rain ditches that were created with melting snow and deepened with non-stop rain we've been having.
I really enjoyed offseting the blade as well as adjusting the angles to create a bigger cut.
Did not enjoy putting on three point hitch (backhoe was in the back) and the blade itself :)
/ Missing 3-Point Hitch Controls? #11
Glad to hear it was a simple solution!
/ Missing 3-Point Hitch Controls? #12
Always read the manuals first :reading:, then second time :confused3:, then while scratching your head :censored: till the light comes on! :applause:
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
