Mirrors for JD 4200
/ Mirrors for JD 4200 #1
mjncad
Super Member
In the civilized First World
A couple
I got tired of twisting, turning and squirming in my seat, so it was time to add some mirrors. I've always liked the looks of Jeep Wrangler mirrors, so I got a pair from J.C. Whitney that are made by OMIX-ADA. These mirrors are supposed to be dual focal point mirrors with the majority being flat for a 1:1 image and the lower portion wide angle. They are more wide angle all over, which is no big deal.
The brackets are made of scrap 3/16" plate I had laying around. I didn't have a welder at the time, so the 1/2" square locating bars are screwed to the mirror bracket. There were a couple of holes in the loader frame that I assumed were there for manufacturing purposes, which is why the bolts holding the brackets to the loader frame are grossly over sized.
DSC00842 shows the brackets just back from the powder coater. I had them done at the same time as the ballast box brackets (separate post), hence the bluish tone to the green.
DSC00840 shows the tractor before the mirrors were installed.
DSC00849 shows the installed mirrors.
DSC00851 & DSC00854 show the view from the seat.
I still have to spin around from time to time; but the mirrors have helped a lot in close quarters and on the road.
/ Mirrors for JD 4200 #2
Hey, that is cool :) In addition to turning around for the normal backing up, I find myself looking behind as I'm going forward when mowing and raking trying to make sure the result is what I expect. I've been think about these for a while, but you've given me new motivation to think some more.
Some questions, though....
Are those mirrors the breakway (foldaway) type that will swivel inward if needed?
Also, how does it do with the normal vibration of the tractor?
Just wondering, did you use a plasma cutter to cut the plate?
/ Mirrors for JD 4200 #3
Sweet job, to bad the paint didn't match better! ;) Should have had a little ( a lot more ) orange in it!!:)
Are those mirrors the breakway (foldaway) type that will swivel inward if needed? Yes, the mirrors swivel either way and I have to retract them so my truck and Wife's car don't hit them in the garage.
Also, how does it do with the normal vibration of the tractor? The vibration doesn't affect them as much as I expected them too, which was a pleasant surprise. Obviously the smoother the surface the less vibration; but they have been very helpful using the brush cutter, rear blade work, or just rock & dirt loader work.
Just wondering, did you use a plasma cutter to cut the plate? A plasma cutter is on my wish list. The basic cutout was done with a Wilton 8201 14" 7-speed metal/wood cutting band saw with a 3/4" wide Starrett blade. The large arc that clears the loader pivot was done on a drill press with a hole saw and motor oil for lubricant. The remaining holes are just good old twist drill bits on the drill press. The remaining finish work was done with a bench grinder. I have been experimenting with compressed air for cooling as I'm tired of the oily mess. It seems to work pretty good and I've put a true compressed air cooling system on my wish list.
Please see replies in red.
3RRL said:
Very nice & clean installation. Those will definitely come in handy. Are they vibration proof mounted there?
Thanks for the compliment.
I'm hoping the Colorado sun will fade them to the proper color. :D
/ Mirrors for JD 4200 #8
alll look at the cute mirrors waiting to be ripped off by tree branches :D
(looks good btw)
/ Mirrors for JD 4200 #9
If you've got that much force where a tree branch will rip the mirrors off then your split second away from getting smacked by the same branch. :)
/ Mirrors for JD 4200 #10
true, but i dont know about you but i have a natrual reaction to bend down or over and out of the way of low lieing brances out of instinct. :cool: your mirror on the other hand.... not as smart ;)
Fortunately I don't have tree branches to worry about. Nothing but tumbleweeds, claycrete dust and the occasional trampoline spring because some fool didn't anchor their tramp to the ground in a high wind area.
We've had two trampolines bounce through the neighborhood in the past year. The last time I mowed weeds, I picked up 11 springs lying on the ground.
/ Mirrors for JD 4200 #12
I put these same mirrors on my Tractor also. They were great. My problem was they broke off at the mirror swivel point. It was like some sort of white metal stud. I intend to drill it out, tap, and put allen head rounded off on lathe back in its place.
/ Mirrors for JD 4200 #13
These also swivel in out of the way. I need to get them redone, I really miss having them to use. John
/ Mirrors for JD 4200 #14
mjncad,
Nice job on the mirrors! My neck is always hurting from looking back while using the box blade. Your place sounds similar to mine (between Falcon and Black Forest, near Colorado Springs).
Nice mirror installation on the loader supports. I thought of doing that type of installation with mine; but in my case it would have blocked off a grease fitting access hole.
Sounds like the white metal you describe is what I call Chinese Alumasteel. It may technically be steel; but it's so soft it may as well be aluminum, or old fashioned pot metal that car trim used to be made from.
horseman1 said:
mjncad,
Thanks! The mirrors are a great help. They don't eliminate the twist; but they reduce it significantly. I also like using them when I'm mowing near the neighbor's fence as there is less chance of whacking a fence post.
I haven't been in that area of Colorado in quite a while; but as I recall, it is similar enough to the Adams/Weld County areas before the terrain rises into the hilly Black Forest country.
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
2006 Kenworth T800 Tandem Dump Truck, VIN # 1NKDLU0X26J147788 (A65563)
2006 Kenworth T800...
Outback Guidance System (A65640)
Outback Guidance...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
