Mini Split Reliability
   / Mini Split Reliability #31
I've looked at a few in stores, but I'm not sure I can justify the cost. Funny thought considering what I've recently spent on another project that I hope gets rarely used.
I'm not interested in cooling the whole house and don't really understand the heat portion. Is it electric (heating elements) or does it use the coolant somehow?
On the cooling side, I'm more interested in drying out the humidity in summer. I only cool one room now with a 6K window shaker and usually have it set in the mid to upper 70s. I couldn't put a mini in that one room for various reasons, so it would have to work for a larger area by several hundred square feet. I'm not opposed to that if it dries the air and doesn't eat too many KwHrs in the process.
And I'm not really sure if I'd want a 110V or 220V unit.
   / Mini Split Reliability #32
^ ductless mini-splits basically just use valving to reverse the flow of refrigerant. You can think of it like running your A/C in reverse - instead of rejecting heat to the outdoor environment, you send cold refrigerant through the outdoor heat exchanger to absorb heat from the outside air. Which is why they really struggle when it gets down near zero degrees outside - theres just no heat to pull from the air.
UNUSED XSTAR 101" X 25' BRIDGE PLATFORM (A54756)
UNUSED XSTAR 101"...
2015 Acura MDX SUV (A55758)
2015 Acura MDX SUV...
2017 Caterpillar 326FL Hydraulic Excavator (A55787)
2017 Caterpillar...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
2019 Ford F-550 4x4 Altec AT40G 40ft Bucket Truck (A55788)
2019 Ford F-550...
