Mini Split Reliability
/ Mini Split Reliability #1
Kyle_in_Tex
Super Star Member
East Central, Texas
JD 4310,JD5420
I've heard some nay say these things, also saying parts and repairs are high.
I'm wondering if those here would care to comment how long they have had theirs? Any problems? What brand?
Also, how well do they heat? Like, do they heat down to 32F decently?
I've read where it is important to get them off the ground to stay cleaner. Install them on a shelf with brackets.
/ Mini Split Reliability #2
I have 5 of them. Unbranded with Mitsubishi inverter two stage compressor. Each unit was around 1000 bucks. I plan to replace them when they break. I installed them myself so labor is free!
We have only been using them for few months. They keep warm fine as long as you keep running them even during the snow storm we had. Expect to pay more electricity bill than gas heating. They should shine in cooling.
I installed them on a plastic pad so they can drain well when in heat pump mode.
Plan to install heaters in bathrooms and walk in closets.
/ Mini Split Reliability #3
I have a 30k BTU fujitsu halcyon as our main A/C and backup heating. The unit and system itself has been perfectly reliable for 6 years now, BUT, we did have a refrigerant leak that no HVAC company could find. Got a few opinions before spending $1k just to evacuate and recharge it. Working well again now, but we'll see for how long.
As far as heating efficiency goes - it does really struggle when the outdoor temps go below ~20f. We never use it when it's that cold out, since our primary heat is the woodstove. But I've tested it during cold snaps, and it really struggles. It kinda makes sense though, you are trying to extract heat from frigid outdoor air and add 50-60 degrees into your house. Versus A/C mode when you max out at around 30f of temperature difference.
/ Mini Split Reliability #4
We've had a single zone 15K BTU Fujitsu Halcyon DC Inverter unit for about 10 months now. Heating and cooling are both excellent, no issues so far. We heat mainly with coal/wood (Harman Mark 3 in basement) but the Fujitsu did a good job this winter as an auxiliary source of heat. Electric bills are significantly lower than they were with a window unit (12K BTU) A/C and baseboard electric heat in an auxiliary role, by $20-30/monthly by my best estimate.
/ Mini Split Reliability #5
Mitsubishi unit at house has been running in auto mode for more than 9 years without a hiccup.
36k btu Mr. Cool had an infant mortality failure on outside unit 2 months after install. Warranty replacement has performed flawlessly for over a year now.
/ Mini Split Reliability #6
Have had our Fujisu units since about 2014 after I sat in the basement in the winter of 2013 in front of space heaters while recovering from congestive heart failure. Work fine at all temps here in central Va. Got one outside unit servicing 2 inside units. Think 1 outside can service up to about 7 inside units. Absolutely no problems. Wife cleans the inside unit filters about every 2 or 3 months. These have no backup.
Our upstairs newest duct type Carrier heat pump runs on heat pump only all the time. Need it to because of the generator. On the old unit, we had an electronic system to keep the backup electric coil from coming on when the generator was on. This newer, more efficient heat pump runs without backup and keeps upstairs warm.
Not so with older 4 ton Carrier unit. The family room with monster front window and sliding doors on back wall to deck and 2 skylights cannot be heated with heat pump only.
/ Mini Split Reliability #7
I have an 18K LG unit that is the only source for heating and cooling. The recent cold wave here in Texas saw 0.0*F at our house and the mini-split did fine. Kept interior temps around 70*F. I did the installation my self and it's been trouble free for 7 years. The only thing we've done is replace the interior fan because the bearings were noisy. Cost about $100 which included the travel & labor for an HVAC company to swap it out.
Note: If you install it yourself, you must use a digital vacuum gauge and really evacuate the lines really good! You should plan on the better part of a day to do the vacuum.
/ Mini Split Reliability #8
I have 10 Senville units. DIY. 4 units are bracket / wall mounted with 6 ground mounted. Over 3 years and only 1 trouble. At the cost, I just changed out the unit. While removing the unit, the location of the freon leak was discovered. The unit is now my spare. The units work great when the temperature is between 28 and 118. Might work great in a wider temperature range but that is about the temperature range witnessed/
/ Mini Split Reliability #9
As far as I'm aware of, there is no such thing as a inverter two stage compressor.
/ Mini Split Reliability #10
For parts availabilty go with Daikin, Fujitsu and Mitsubishi.
You're smart asking about the heating requirements as there are no strip heaters in mini splits anymore. Any competent HVAC contractor should be able to let you know exactly what you're getting with any model from any manufacturer.
/ Mini Split Reliability #11
You probably have a 30RLXB unit. 2.5 ton of air conditioning.
The question is, if you needed 30k of cooling, exactly how much heat did you need at what outside air temperature design condition?
Since you already have a primary heat source other than a mini split, I can only guess that the installing contractor gave you a lower price on a system that could produce less heat vs a system that could produce more heat, but being more expensive.
If you had a refrigerant leak and the HVAC contractor could not tell you where the leak is coming from, but still charged you 1k to evacuate and recharge it, I would never use that contractor again. You don't spend a thousand dollars to just roll the dice and hope for the best IMO when the leak is either coming directly from the equipment coil (indoor or outdoor) or line set and or connections.
/ Mini Split Reliability #12
I have two 36,000 btu Mitsubishi units with 7 heads rated to produce heat down to 25F.
They are going on 6 years old, my AC cost in the summer are significantly lower then with multiple window units.
They do a good job of heating in the fall before I light up the coal insert, and in the spring when it goes out.
My primary heat is an oil fired boiler the split units are a bit less costly then the oil.
Here is a link to a very good heating cost calculator for most any fuel;
Fuel Comparison Calculator for Home Heating | Coalpail.com
You enter the cost of your available fuels and the actual efficiencies and see the actual cost per million btu
/ Mini Split Reliability #13
I have a 12K Btu Mitsubishi unit, only thing I have done to it in the 8 years we have had it is to clean the fan 3 times. Doesn't provide much heat below 20dF outside so we fire up the wood stove anytime temps get below 25dF. Newer units will provide heat to 0dF.
/ Mini Split Reliability #14
Yep I think you pretty much nailed it. We had three repair opinions from HVAC folks around here, at $100 a pop, and they all quoted me exorbitant prices just to find the problem before even possibly correcting it.
The final company we went for repair with pressurized the system and it held for hours, so it's a little confusing how we could have lost all our refrigerant. Maybe it was under filled from the start and just limping along? We knew and agreed that we were taking a gamble by simply refilling it and hoping it holds. But I was a bit tight on cash and it was a heat wave in July, we needed it working, and thats what we got. I think it was actually only ~$800, but that still felt like a lot.
I think our original installing contractor just didn't really know what he was doing. We probably don't need 30k of air conditioning, heck, some summers we hardly use it at all. Our house is super insulated and partially earth-bermed, it stays nice and cool unless a multi day heat wave comes along, which isn't every summer in Michigan. And we only use it for heat during the shoulder seasons (fall/spring) when its too warm to justify firing up the woodstove. So it's always running well below its full capacity, not ideal.
/ Mini Split Reliability #15
The realtiy is that 30k unit would run fine for only needed 10k of air conditioning if that is all the load that is required.
With mini splits and inverter compressors, as long as you know what you low range is for cooling and that will work for cooling, you generally oversize the AC to hit what you need for heating. One reason why a load calculation (if done properly LOL) is important, particularly with mini splits. Point being, capacity use to be rated arund 50%, so you're fine not wasting anything running below it's maximum capacity.
If the system had the "leak" within the manufacturers warranty, I would of nailed the installing contractor. Leak is either in the indoor coil, outdoor coil, or line set or line set connections to the indoor and outdoor unit. Charge could of been off depending on line set run as contractor HAS to add additional charge generally by the foot after 15' . Other issues if going down that rabbit hole, but IMO the installing contractor should of been able to figure that out at worst case, talking with technical.
/ Mini Split Reliability #16
Minisplit AC systems first started out in the Asian market by Mitsubishi in 1960, and was called the ductless AC systems. Central Air Conditioning, which is very common in the US, is just not utilized in Asian homes. Typically each room has it own minisplit, and you only operated the minisplit in the specific room your currently in. My house there has 5 Mitsubishi minisplits installed in 2007, and they are still working very well 14 years later. Only maintenance required was an occasional refrigerant recharge. In the long run, I found they were significant electric power savers and reliable.
After finding there way to the US, heat pumps are now incorporated into the minisplits.
/ Mini Split Reliability #18
3 heads on a mitsu hyperheat. we ran it when it was 20 below and it was still heating when our boiler could not keep up. about 2 years in and no issues. it was the only way we could really add AC to our house and its so nice in the summer.
/ Mini Split Reliability #19
Either your boiler / radiant tubing was undersized or your mini split was oversized if a mini split could out perform a boiler for heating;)
Mitsubishi did a great job with that marketing term. The reality is other mini split manufacturers have the same heating performance, and in some cases outperform the Mitsubishi. No different than Carrier with Puron and hybrid heat.
When it comes to heat in very cold weather, nothing can be hydronic/radiant IMO.
/ Mini Split Reliability #20
I have a 3 head Sanyo system in my shop that is 20 years old. It still works great.
The only issues that I have ever seen are all installer induced. Poorly executed flare connections are very common. But the equipment is very reliable. I would definitely stick with the “big” names for parts and support in the long run.
