Mini Modification
/ Mini Modification #21
Looks like you’re putting it through its paces and having some fun I like the seat. What you got under the cover on the other side a Honda VTX?
/ Mini Modification #22
It's a Suzuki Intruder VS1400. It's for sale too. :( 1995 Suzuki Intruder 1400
Can't have too many toys at once... so the bike and ztr must go.
/ Mini Modification #23
KMA said:
I took pictures of my newly installed TSC suspension seat and spinner knob. I wanted black, but they didn't have it... so I went with the JD "look". :D (Yes, I know my PT needs some cleaning... :eek: 14 hours of use in just over a week of ownership)
The seat sits much higher and is a bit harder to get in and out of, but it does seem to take the edge off of the bumps. My property is mostly clay that hardens like a rock and makes for a very rough ride.
I've had that seat on my 1430 for a couple of years and it's worked out well. The thing I found,once I installed it, was that the extra height made steering easier without the spinner, so I took that off.
/ Mini Modification #24
Very nice looking setup. I'm normally a Harley Man, I've had two of them, along with numerous other bikes, street and trail.
These days I would be doing more two up riding with the wife, so I would want all the weight and power I can get. I’ve been eye balling the new Vulcan 2000 classic. Looks like it would be a nice bike to customize. Then again, that’s another topic for another forum.:rolleyes:
/ Mini Modification
I think moving the lights up to the ROP really helped with night use.
/ Mini Modification #26
I hope to pick up the ROP and 60" finish mower in the spring, and I will definitely be moving the lights up there. (along with adding a cup holder ;) )
With the additional height of the suspension seat, reaching down to curl the bucket on the mini-hoe was killing my back. So here's another small modification I did yesterday. Cost was about $15. $5 for the 1/2" stock and $10 for the shifter knob (clearance bin at Auto Zone). I decided to keep the green/yellow theme going... :) :D
/ Mini Modification #27
I"m going to do that one. Can't get much simpler than that.
/ Mini Modification #28
Very nice. :)
/ Mini Modification
Good idea. What is the stock material? Also can be get a picture of how the stock attaches to the valve?
/ Mini Modification #30
It was 1/2" round, 36" long cold rolled steel I believe. I got it at either Lowe's or Home Depot (can't recall). I grinded the last few inches of the end flat to match up with the stock part. Essentially, I tried to make the end look as much like the original part as possible.
/ Mini Modification
That's very helpful. Thanks.
/ Mini Modification
Welcome back. Have you made any recent modifications that we don't know about?
/ Mini Modification #35
Hydraulic Tank Temperature Gauge
/ Mini Modification
Would that work on the engine as well? It looks like you have room for two guages.
/ Mini Modification #38
MossRoad said:
That's pretty slick. Can you give us some more info on the guage and the sensor?
Taylor battery operated panel mount with remote sensor. The sensor is inserted in a well near the middle of the tank
sg
/ Mini Modification #39
Ordered a Tiny Tach commercial model for the other side. The Tiny tach would not work at all with the Kohler engine. I was looking for a multi function gauge that you could switch between sensors ( CHT, EGT and Tank Temp.) Had to settle for the Taylor thermometer. The Tiny tach people told me they were working on a cylinder head temperature gauge I do not know the status of that.
sg
/ Mini Modification #40
Clarke,
What is the highest hydraulic temperature you have seen. What was the outdoor ambient temperature at the time.
Duane
2012 VOLVO VNL64T630 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2012 VOLVO...
Case IH 950 Planter (A63688)
Case IH 950...
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
2016 Bobcat E20 Mini Exacavtor (A61572)
2016 Bobcat E20...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
