Mini Dozer - Project near complete
/ Mini Dozer - Project near complete #162
when you look on ebay, search for Meyer plow pump.
they aren't hard to rebuild and can sometimes be had cheap.
/ Mini Dozer - Project near complete #164
Did you ever hook up your motors to direct drive like you were thinking about?
No I had not done the direct drive yet. While moving to the direct drive seemed simple at first it became more challenging. Where I thought I could put the motors resulted in few sprocket teeth engaging the track (less than 3). I was concerned about that. In order to put the motors in a better location (better wrap on the sprocket) would have required lengthening of the tracks. Due to these challenges I slowed my modification.
/ Mini Dozer - Project near complete #166
I wonder if using gears would work very well. I don't have a clue where to look for gears that would be big enough though. Then how would you keep them lubed up and clean enough? There must be some way to transfer power to the tracks in a foolproof way.
/ Mini Dozer - Project near complete #167
How much did it cost to build the mini bulldozer
/ Mini Dozer - Project near complete #168
Do you think I can do this with a Murray.
/ Mini Dozer - Project near complete #169
I see this is an old post but perhaps if you don't mind answering a question. The hydraulic motors I see in the photo above I am curious about as far as specs. RPM, pressure requirements, and ECT.
I never totaled the expense of the project. I would estimate $500-700 by the time I was done. The dozer had worked pretty well since I completed it. Currently things are not working but that is due to some problems with the engine. The older Kawasaki engine has been tougher to get parts. First it was the float needle and seat. Now the igniter is shot. Trying to figure if I should just replace it or keep fixing it.
/ Mini Dozer - Project near complete #173
I think is time to replace if it's costing more down time then running time
/ Mini Dozer - Project near complete #174
There was a few earlier threads about mini dozers. I am nearing completion of my project. Basically I took a riding mower with a bad rear axle and built a subframe for it. The sub frame consists of the tracks and hydraulic motor mounts. In the tractor frame I mounted a zturn pump/control unit. The first couple test runs seem fine but I have issue with the rear chain drive tension. Basically the chains from the hydraulic motors to the track jump off. Hope to get it solved this weekend. I will post some additional pictures.
I don't know if you completed this project but I used to do a lot of business with a few of the Caterpillar plants including a few excavator plants. If you can scavenge some wheels off an old boat trailer, they might be just the right width to support your treads. They are covered in rubber so the are quiet and combined with the trailer's leaf spring might give you the necessary tension. There often configured in a "H" pattern with 4 wheels and are fairly stout and offer a gap in the middle to clear the chain links. Try a marina, these parts would outlast the trailer's frame, so I'd offer a low sum.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
Adams 16T Tender Body (A63688)
Adams 16T Tender...
78'' SKID STEER BUCKET (A61572)
78'' SKID STEER...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
