Miller Legend Help
/ Miller Legend Help #1
loudhornsrule
A man down the road has a late model Legend (06 maybe 07- don;t know the exact number) for sale. Are these good welders? I have had several miller bobcat 225's. I build some pipe fence around my place, and might weld up a plow. Will this do everything a bobcat would and maybe more? thanks
/ Miller Legend Help #2
If you can't get any info here. The welding web forum has a Miller section, where I'm sure they could help you out.
/ Miller Legend Help #3
I have a Legend. It is the second one I have had.
They are a much better welder than a Bobcat in my opinion. It isn't as good as a Trailblazer, but then few other welders are.
Pluses, great welding cycle.
Minuses, the create 60 cycle voltage only at idle. So if you want to use it as a generator it is the cat's meow. Bobcats and Trailblazers rev up for ac use, Legend just purrs. But if you want to use ac, grinders etc, anything with a brush motor, they have a low amp plug that provides 90 cycle 110 volts only while welding.
2000 FREIGHTLINER FLD120 (A67714)
2000 FREIGHTLINER...
2025 28in Forks and Frame Mini Excavator Attachment (A66734)
2025 28in Forks...
2021 Berti 112in. Handy 230-280 Hydraulic Flair Mower Tractor Attachment (A66734)
2021 Berti 112in...
PALLET OF MISC TRAILER PARTS (A68842)
PALLET OF MISC...
1996 DODGE RAM 1500 LARAMIE SLT EXTENDED CAB TRUCK (A65057)
1996 DODGE RAM...
2008 FORD E-350 CARGO VAN (A66091)
2008 FORD E-350...
