Military generator MEP003A
   / Military generator MEP003A #1
Ron3396
Alamosa co.
A C wd45
I just got a military generator a MEP003A and I also got a MEP002A the first is a 10 KW gen the other is a5 KW, I just got them home and I wanted to see what I got so I went out and got 2 new battery's they work on 24 VDC,and nothing :confused::confused:,the switch looks ok, but , maybe there is some kind of switch I don't know about. I'm thinking about shorting across the starter to see if it will turn over, but I thought I might talk to someone that may know more than me first.
Well today I changed all 3 fuel pumps and tomorrow I'm going to Chang out the control box and give its an other chance, after that I don't know what s left
   / Military generator MEP003A #4
:welcome: to TractorByNet! :thumbsup:
If you got it to turn over, did you bleed the fuel lines at the injectors?
   / Military generator MEP003A #5
Did you get it to turn over?
   / Military generator MEP003A #6
What did you buy for batteries? How did you have them wired up?
Take a couple pics?
   / Military generator MEP003A #7
Are you not getting fuel? Is that why you changed fuel pumps?
2016 Hyundai Tucson (A53424)
2016 Hyundai...
2016 Ford F-750 14FT Utility Flatbed Truck (A52377)
2016 Ford F-750...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
