Mig gun
/ Mig gun #1
weldermike
Platinum Member
kubota L4400
Does anyone know of any companies that make a mig gun with a flex head like some tig torch companies do?
/ Mig gun #2
I know bernard and tweco make flux core guns with a flex head, not sure about mig guns though.
/ Mig gun
Cool! Thanks mark, gonna look into it. Work in a lot of tight spots, tired of twistin myself up like a pretzel!
/ Mig gun #5
Look up the Tweco Knuckle Head. Comes in several knuckle lengths and amp ratings. The Knuckle head uses knuckles instead of coils so when it gets hot it gets tighter instead of looser. I saw one hooked up to a robot at Fab-Tec and it was on it's 30,000th flex without failing.
/ Mig gun
Thanks yomax, gonna check it out!
/ Mig gun #7
I had the tweco flex neck on a tweco 400 amp MIG/FCAW gun. I was not impressed at all. It was fairly costly and lasted about a month. Not sure if it was a lemon or what. I went to the Lincoln 400 Magnum MIG/FCAW with lincolns flex neck and have not looked back.
/ Mig gun #9
The Tweco has a 1 yr. warranty. I accidentally tore a hole in my knuckle head and they replaced it n/c. I had the Lincoln one 1st and diddn't like it at all. I guess everyone likes something different. The Bernard one gets pretty loose after you weld with it a while.
/ Mig gun #10
I didnt know that about the bernard guns, I only recomended them because I have heard good things about bernard guns in general, and I have a bernard shortstub on my stick welder and love it.
/ Mig gun #11
Bernard does have good products. No question. I use a Short Stub type for my Stinger too. Nice to be able to bend the rods and they hold firm. I used to sell a lot of Bernard. Most Mig guns out there are very good these days.
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2003 TEREX  60 TON CRANE (INOPERABLE) (A67714)
2003 TEREX 60 TON...
2013 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2013 ALLMAND...
2002 PETERBILT 330 WATER TRUCK (A67714)
2002 PETERBILT 330...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
