Midwest aerator?
/ Midwest aerator? #1
hamsey
I am looking at the Midwest 48" core aerator. I will be using it on my BX2350. Anybody have this aerator? Pros/Cons. Other recommendations. It weights 245# so using it on the 3pt should not be a problem. Thank you!
Norm
/ Midwest aerator? #2
I have a Ferguson over seeder. It's a round spiked roller that has a box over the roller that drops seed, lime or fertilizer. The roller can be filled with water to add weight which will make it dig deeper holes for aerating, fertilizing or seeding/over seeding. My brother has the magazine yard and he loves it and uses it more than me. I've pulled it easily with my done gone BX1500 so I know my BX2350 will handle it easily. I heard about it and had Barlow Farm equipment get me one a few years ago. It's a very versatile attachment. It was mentioned in an old thread which I will post an answer to and see if it brings it to the front for more info and opinions.
/ Midwest aerator? #3
I have the Kioti aerator which is mfg by Midwest. I have had it since March 03 and gave $735 for it. It works OK no problems. I put 7 solid concrete blocks on the top to add weight to get the cores to penetrate on our hard clay soil. I do not think u will have the same problem I have with a BX2200, the 3 point does not lift the aerator high enough to get the tines more then a 1-2 inches off the ground. I had to make some modification to the lift points and now that is not a problem.
/ Midwest aerator?
NY,
What did Kubota change? I would have to purchase the aerator in CA and have it shipped to CT. Not sure I am willing to take a chance without trying first. Not very many options. I did the the pro-aire aerators but I worry about it being too heavy.
Norm
/ Midwest aerator? #5
hamsey said:
NY,
Norm
They changed the width and height of the 3 pt. So I believe you will not have a problem.
Have you gotten quotes from a local Kioti dealer? They may even have one in stock, since it is the same unit only with Kioti name instead of Mid-West.
/ Midwest aerator? #6
Buy the Pat's Quick Change Hitch. It extends you arms just enough that it will lift your tool a lot higher. I had a BX2200 and had the same problem with my Blade and Box. Got the quick hitch and that all changed. I also didn't cuss and sweat as much hooking them up.
/ Midwest aerator? #7
Only problem with a quick hitch is all my other tools with PTO's will not fit as the PTO shaft would be too short.:mad:
/ Midwest aerator?
Thanks for the information. I will check and see if I have a Kioti dealer. Do you know anything about Pro-Aire aerators?
Norm
/ Midwest aerator? #9
Just an FYI. The quick hitch extends the center 3 1/2 inches.
/ Midwest aerator? #10
Another thread that might help you out:
http://www.tractorbynet.com/forums/kubota-owning-operating/110595-core-aerator-3.html
teachdocs said:
I have been very happy with my Turf-Aire core aerator. I purchased the tow behind with hydraulic lift so you can maneuver corners and make tight turns without lifting the 3PTH.
There is a big difference between a quality core aerator and the cheaper, lightweight units. This unit will pull 3-4 inch cores consistently in the Spring and Fall turf.
When loaded with additional ballast weight, it will put a big load on the BX23 to get it started, but then runs effortlessly.
I ran hydraulic lines to the front loader valve and use the joystick to operate the hydraulic lift. Very simple and easy to use.
I have not had any problems or repairs with the unit. It is a bit expensive, but you get quality and an extremely well built unit that will last forever.
I intended to purchase the unit for my own property, but it turns out that people drive by and ask about it. I have done enough "side" jobs to pay for the unit already.
Turf-Aire Coring Aerators
Good luck
http://www.tractorbynet.com/forums/attachment.php?attachmentid=89249&stc=1&d=1194972179
/ Midwest aerator?
Teach,
Thanks for the reply. I contacted Kubota about the limited 3pt hitch on the BX2350. The reply I received was the the lower arms only spread to 20", I contacted Turf-Aire and was told that the arms would have to spread to 26". I might see if they can modify it for me.
Norm
/ Midwest aerator? #12
Thats odd as I have a 26" drawbar on my BX2350:confused:
/ Midwest aerator? #13
It will fit just fine.
You can always turn the implement pins inward and it will be less than 20 inches.
Please consider the tow version. The PTO style requires a lot of patience and extra work on the corners. You basically can only go straight when the implement is the ground. Strap on a tow and drive as fast and wherever you want.
/ Midwest aerator?
I thought it sounded a little odd but it came straight from Kubota. I was going to verify it but did not have a chance over the weekend.
Norm
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2013 Caterpillar 305.5E Mini Excavator (A64553)
2013 Caterpillar...
2013 Nissan Versa Sedan (A64557)
2013 Nissan Versa...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2022 EZ-GO ELITE...
2013 Keystone RV 19FBPR 23FT Trailer (A64557)
2013 Keystone RV...
