Middle Buster & Subsoiler
/ Middle Buster & Subsoiler #21
They can aslo be used (very carefully) to breakup to remove old sidewalks.
/ Middle Buster & Subsoiler #22
I have a combo unit (from Northern). It is now set up as a middle buster and if/when I change it to a subsoiler I will have to replace the plow bolts which hold the blade to the shaft. They rusted in place within a few weeks of the first time I used the middle buster. I should have applied a thick layer of anti-sieze (or some type of heavy grease) when I assembled it.
Ed
/ Middle Buster & Subsoiler #23
Alan,
Thinks are the same all over. I hope your wife didn't catch you. Mine's asleep.
Buck
/ Middle Buster & Subsoiler #24
What would be the minimum tractor horsepower required to effectively use either of these units, to ultimately get 12"-14" deep?
/ Middle Buster & Subsoiler #25
It has been my experience that HP is not an issue. I have seen 18hp Yanmars do just fine with a middle buster. I use a 25hp zetor with one. What matters is the amount of traction. You may have to weight the tractor down to keep it from spinning. My neighbor with the yanmar had to fill his tires with CaCl to get the traction thru his hard ground. I have weights and antifreeze in mine.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2001 International 4000 DT 466E (A60462)
2001 International...
2009 Jeep Patriot AWD SUV (A59231)
2009 Jeep Patriot...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
MMS 90B Hand Held Trowel (A60463)
MMS 90B Hand Held...
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
