Middle Buster & Subsoiler
/ Middle Buster & Subsoiler #21
They can aslo be used (very carefully) to breakup to remove old sidewalks.
/ Middle Buster & Subsoiler #22
I have a combo unit (from Northern). It is now set up as a middle buster and if/when I change it to a subsoiler I will have to replace the plow bolts which hold the blade to the shaft. They rusted in place within a few weeks of the first time I used the middle buster. I should have applied a thick layer of anti-sieze (or some type of heavy grease) when I assembled it.
Ed
/ Middle Buster & Subsoiler #23
Alan,
Thinks are the same all over. I hope your wife didn't catch you. Mine's asleep.
Buck
/ Middle Buster & Subsoiler #24
What would be the minimum tractor horsepower required to effectively use either of these units, to ultimately get 12"-14" deep?
/ Middle Buster & Subsoiler #25
It has been my experience that HP is not an issue. I have seen 18hp Yanmars do just fine with a middle buster. I use a 25hp zetor with one. What matters is the amount of traction. You may have to weight the tractor down to keep it from spinning. My neighbor with the yanmar had to fill his tires with CaCl to get the traction thru his hard ground. I have weights and antifreeze in mine.
2025 Sickle Bar Mower Mini Excavator Attachment (A66734)
2025 Sickle Bar...
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
LIPPMANN HEAVY DUTY ROCK SORTER (A66734)
LIPPMANN HEAVY...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2015 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2015 Autocar...
2015 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2015 WINSTON...
