mid PTO
/ mid PTO #11
> What you don't want is a
transmission driven PTO. If the rear wheels aren't turning, neither is your PTO.
Not exactly. There are some very rare pto's that can be set to move at different speeds depending on what gear you are in - a ground-speed pto.
But the tranny pto will work just fine in any gear - including nutral or reverse - and be spinning at a constant speed relative to the engine rpm.
It will not be powered any time the tranny clutch is pushed in.
The comments about it not being as good, and the dangers with a heavy flywheel-type implement are valid. But you can run the pto in neutral just fine.
--->Paul
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
FORKLIFT (A56857)
FORKLIFT (A56857)
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2016 Ford Fusion AWD Sedan (A59231)
2016 Ford Fusion...
