Mid PTO Cover?
/ Mid PTO Cover? #1
Yankee
Southern NH
Kubota B7610
Anyone know if a cover for the mid PTO is available (B7610)? Just strikes me that covering it would be better for rust protection and to keep off the dirt buildup. It doesn't look like it would take one, though.
Bill
/ Mid PTO Cover? #2
When I bought my BX2200 a year and a half ago, I asked the dealer for a mid PTO cover. He told me that there is not a cover available for the mid PTO for any of the Kubota tractors.
If you find one, let me know.
John
/ Mid PTO Cover? #3
A cover came standard with my L3010 3 years ago. It is a safety item. I would think they are standard for all the machines.
Kevin
/ Mid PTO Cover? #4
A cover for the rear PTO came with my Kubotas, but not for the mid-PTO, and I never figured out any way to put one on the mid-PTO if I'd had it.
/ Mid PTO Cover? #5
I also asked the dealer after I received my BX1800 and they said there was no mid cover. I would think that would be important for preventing damage when MMM not connected, but apparently the MFG isn't concerned about that. The only reason the provide the rear one is for safety reasons I'm sure. Heck it's kinda hard to get to the mid one to hurt yourself.
/ Mid PTO Cover? #6
as long as we are on mid pto topic, was wondering, i don't have an implement the uses mid pto. , but would it be a good idea to engage it every so often? have had the tractor 3 years now and never engaged it.
/ Mid PTO Cover? #7
Engaging it occasionally sounds like a good idea to me, Frank, but since I never had any implements that used the mid-PTO, I never engaged them on either of my Kubotas. I guess I actually never knew for sure whether they even worked. /forums/images/graemlins/laugh.gif
/ Mid PTO Cover? #8
Bird: was thinking that i will just leave well enough alone, can not envision needing the mid -pto .
/ Mid PTO Cover? #9
My mid-pto cover is just a rubber hose.
/ Mid PTO Cover? #10
Almost looks like heat shrink, but that is certainly a good idea. /forums/images/graemlins/smile.gif Have you started selling your hydro filter cover yet? To me that still looks like one of the best mods done.
For the first time the other day while plowing my garden, I hit a stick and it drove up into the underside and made a heck of a noise. I thought on no! /forums/images/graemlins/blush.gif I immediately stopped and crawled under the unit to find I was lucky and it only hit the front drive shaft. I did tear the boot some as I was in 4wd because of the plowing.
At that point all of the past posts I had read about an under belly shield had went through my mind. Was looking at what it would take to make one, but concluded it would be difficult to make it compatible with the MMM so it would have to be something that swapped out with the MMM as when the MMM is all the way up the gear box is tucked up between the frame rails.
/ Mid PTO Cover? #11
</font><font color="blue" class="small">( He told me that there is not a cover available for the mid PTO for any of the Kubota tractors. )</font>
That might be a true statement for current Kubota tractors, but B2150s came with a mid PTO cover, and I STRONGLY recommend the use of a mid PTO cover on all B2150s. When I bought my B2150 used it did not have the cover. In my opinion Mid-PTO covers are quite as important when the rear and mid-PTOs can be operated independently.
Here is my war story:
One design feature that I consider to be a BAD design for the B2150 is that both the rear and mid-PTOs run off the same PTO OFF-ON lever. One day while using a rotary mower in tall DRY grass (about as tall as the rear wheels) I kept noticing an occasional burning smell. I stopped the tractor a couple of different times to look for signs of trouble and never did notice anything. Then I noticed a smoldering wad of grass about the size of my fist laying where I had just mowed. It turns out that grass was getting wound pretty tightly around my spinning mid-PTO shaft and the subsequent friction nearly caused a fire. While I was fortunate enough to not start a fire in extremely dry conditions, I did suffer damage to the mid-PTO shaft seal and had to replace it.
I then went and got a mid-PTO cover from my local Kubota dealer. No further problems.
Kelvin
/ Mid PTO Cover?
Thanks, guys. I'll call the dealer and let you know.
Bill
2018 32ft Forest River Lacrosse 3211RK T/A Travel Trailer (A66738)
2018 32ft Forest...
2018 BOBCAT E26 (A68134)
2018 BOBCAT E26...
2005 Sterling Cab (A66736)
2005 Sterling Cab...
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
FUEL TANK WITH PUMP (A68842)
FUEL TANK WITH...
