mid or rear mower?
/ mid or rear mower? #1
Anonymous Poster
Epic Contributor
I see that rear mowers are less expensive, and presumably easire to put on and take off. Do they do as good a job as a mid mount? What are the advantages and disadvantages of each?
/ mid or rear mower? #3
I have been using a new Woods 72" rear discharge 3 pt hitch mower this spring as a finish mower on bluegrass and I am more than happy with the results. It follows the ground contour well and dispurses the grass out the rear evenly. With the rear discharge each blade throws the grass out the back, with a side discharge mower the grass is thrown from one blade to the next. The advantages of a belly mower are that you can mow closer around trees etc and you don't have to look backwards to watch the mowing. When you turn a rear mount the back of the mower can hit objects if you don't pay attention. A belly mower only has the front tires going over the grass but we have had no tire streak problem so far with our Woods and 3010 which is heavy for mowing. In my case a belly mower was $2800 and the Woods rd7200 was $1500. You can buy parts for a 3pt hitch anywhere while the tractor mower parts are more expensive. It is all personal preference and what you are used to. A 3p mower serves are needs well.
/ mid or rear mower? #4
i use a befco 5 ft. 3pt rear discharge mower. i like to take off all equipt. when i am useing the fel.i guess it depends on your personal needs. i am taking my mower on and off all the time ,so i like the easy way it comes off. hope this helps. frank
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
3pt 4' Rhino SE4 (A64127)
3pt 4' Rhino SE4...
Brake Drums (A62613)
John Deere 7230 (A62180)
John Deere 7230...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
