Mowing mid mount mower deck pto problem
/ mid mount mower deck pto problem #1
marthaiseki
Lewes England
Kioti CK35 TYM 237
Morning guys, Ive a JCB 327 (which is TYM 273) with a mid mounted 1500 mower deck. I bought it second hand and have gone through it servicing everything. I replaced the transmission case sump bung as it was all mashed up (using JCB part) and once i started using the mower i found the reason why....
The mower deck pto drive fouls the bung when the deck raises - either when hitting high ground or if raised using hydraulics.
My reckoning the way to fix this is a flush fit sump plug (cant find one) or a narrower diameter pto shaft or is there another fix?
Any help much appreciated thanks
2020 AUTOCAR XSPOTTER TRUCK (A65057)
2020 AUTOCAR...
2021 CATERPILLAR 316FL EXCAVATOR (A65056)
2021 CATERPILLAR...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2002 FORD E350 CARGO VAN (A66091)
2002 FORD E350...
2005 PETERBILT 379 (A67714)
2005 PETERBILT 379...
YALE 4K FORKLIFT (A67714)
YALE 4K FORKLIFT...
