MF5465 Rev counter problem
   / MF5465 Rev counter problem #1
Baldy farmer
MF 5465
MF5465 2010 model with Perkins 6 cylinder. Rev counter keeps creeping up by a few hundred revs, engine remains the same. Has anyone any suggestion. Can’t find a sensor or any clue what it could be.
   / MF5465 Rev counter problem #2
Welcome to the forum. (y)
I don't know your tractor so is it an electronic or mechanical Tachometer?
If it's mechanical, the cable probably needs lubed. If it's electronic, it could be a corroded connector or a bad head.
Found out it’s electronic tacho and just changing sensor which is neatly hidden behind the fuel filter. Will give it a try and see if it solves the problem. Sensor is bloody expensive £175. So fingers crossed it works.
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2009 SolarTech Silent Messenger III Solar Message (A53117)
2009 SolarTech...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
